Error in generating gcode?
K0nrad
Post by K0nrad » Wed Jan 26, 2022 9:13 pm
I have encountered the following problem: when generating the path for my profile (see files), the lowest part of the path is lost. It looks like a very long tab but I did not declare it in that way. Is it my mistake or problem with the CAM module?
Konrad
Test1.dxf
(792.67 KiB) Downloaded 70 times
Re: Error in generating gcode?
Post by andrew » Wed Jan 26, 2022 9:29 pm
I can confirm.
Can you change the length of the tab at the bottom from 4 to 3.5 and try again?
K0nrad
Post by K0nrad » Wed Jan 26, 2022 10:08 pm
I have changed the tab length as you suggested. Unfortunately, it had no effect (see picture) :-(
Konrad
Post by andrew » Wed Jan 26, 2022 10:11 pm
I cannot reproduce that (with tab length 3.5) Could you attach your DXF and G-Code again?
Also, please indicate your QCAD/CAM version and operating system (see forum rules above).
K0nrad
Post by K0nrad » Wed Jan 26, 2022 10:14 pm
Fixed. I changed the length from 4 to 3mm and it works :-)
Any idea what might have been the cause?
I work with the latest release of QCAD/CAM. win10 OS.
Konrad
