Automatic line division: How I do ?
Whiskey
Post by Whiskey » Wed Jul 01, 2020 11:08 am
I have a little problem with the QCad software, finally on what I want to do.
What I want to do is use QCad to make my plans in 2D and import them in DXF in blender.
It works pretty well except for a few annoying details such as poorly extruded faces.
The solution to work around this problem is to split each line as soon as another line touches or passes through it in QCad.
The Divide Default Tool (DI) works perfectly to do this job. I can also use the command "Break out Segment (D2)" by unchecking the option to delete the line.
The worries ? On a small drawing the use of these tools is easy and rather quick. The problem is mainly for medium and large size drawings. Doing this for each line quickly becomes a long and tedious chore.
Is there a way to be able to select all the lines and do this job automatically ?
Thank you.
Re: Automatic line division: How I do ?
Post by andrew » Wed Jul 01, 2020 11:40 am
Not out of the box. You'd have to use a script to do that.
Whiskey
Post by Whiskey » Wed Jul 01, 2020 11:53 am
I see, thank :)
