Scaling Issue
JLAR
Scaling Issue
Post by JLAR » Mon Jun 29, 2020 6:03 pm
I am working with DXF files and when I attempt to scale to a new size, QCAD shuts down. This has happened MANY times and I am seeking a solution. In the last attempt, I scaled to .39 and it seemed to be fine. However on my next function, it shuts down..... Any help would be awesome.
Re: Scaling Issue
Post by CVH » Mon Jun 29, 2020 6:29 pm
I suspect an installation issue or a file issue.
could you provide an example file?
QCADpro 3.24.3.10 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
Return to “Chat”
