No snap on intersections in a bloc
J-J
Moderator
Post by J-J » Mon Mar 09, 2020 6:18 pm
I remember running into that situation a while ago. Now, I have a case of a simple bloc, when I try to attach some dimensions lines, the intersection snap is not operative. I only get "on entity". In bloc edition mode, the snap works as expected. Scratching my head!!!
coude 230x45.dwg
(19.57 KiB) Downloaded 59 times
JJ Win7 pro-64
Re: No snap on intersections in a bloc
Post by Husky » Mon Mar 09, 2020 7:00 pm
Hi J-J,
that was a bug in that particular QCAD version. It was reported and fixed. Try the newest snapshot - it should work like a charm now ... :wink:
J-J
Moderator
Post by J-J » Mon Mar 09, 2020 7:43 pm
Hi Husky
It does indeed, thanks :)
take care
JJ Win7 pro-64
