Free Stand Alone Basic Hatch Pattern Tool *Full Version*
John Hyslop
Post by John Hyslop » Sun Feb 02, 2020 9:54 am
Hi All
This is a full version "not crippled in any way" at the moment It has 5 patterns in it, my intention is to have a few tabs with basic instructions and easy to understand input with a diagram you can relate too..
Try and keep your patterns within 1inch x 1inch for imperial and 25mm x 25mm for metric
Things to do:-
Windows Version Runs In LINUX with WINE, very fast and stable..
see change log in zip file...Comments are welcome, new patterns will be added to next versions...
Just removed DEMO versions,they were downloaded 9 times.
Full Free Version 2.0 Downloaded 7 Times...
Enjoy
Cheers
John Hyslop
John Hyslop
Re: Free Stand Alone Basic Hatch Pattern Tool *DEMO*
Post by John Hyslop » Mon Feb 03, 2020 7:44 am
You're not limited to bricks, you can use the Brick-01 Tool to make Roof Tiles too..
Screenshot of 3 variants using "BHT-DEMO-V1.02" :D
Brick-02 Tool 3 variants using "BHT-DEMO-V1.04" :D
Full Version Uploaded now....Last Post
Weatherboard Hatch.jpg (18 KiB) Viewed 896 times
Grille-01 - Grille-02.jpg (44.96 KiB) Viewed 897 times
Brick-02 Tool.jpg (52.84 KiB) Viewed 943 times
Made with Brick-01 Tool.jpg (60.62 KiB) Viewed 943 times
John Hyslop
Re: Free Stand Alone Basic Hatch Pattern Tool *Full Version*
Post by John Hyslop » Fri Feb 07, 2020 2:27 am
Hi All
Just Tested in MINT LINUX using WINE to run, runs fast and stable, so no need for Linux Version
Linux MINT.jpg (79.64 KiB) Viewed 864 times
John Hyslop
Post by John Hyslop » Tue Feb 11, 2020 7:45 am
V2.1
BRICK-02 & GRILLE-02 Now Have
Option to Change Gap in Y
Freeware BHT-V2.1.zip
(251.77 KiB) Downloaded 58 times
Hatch Examples.jpg (37.37 KiB) Viewed 742 times
New Version.jpg (22.15 KiB) Viewed 742 times
