Inside Hatches, more than meets the eye
Panchdara
Re: Inside Hatches, more than meets the eye
Post by Panchdara » Sun Feb 23, 2020 9:37 am
John Hyslop wrote:
Fri Feb 14, 2020 11:06 pm
Hi CVH
I've given users the wrong information... I said to set the origin to X0Y0 on objects far from drawing datum
I should of said set Hatch origin to object datum.... see screenshot example of GRAVEL Hatch Pattern.. also
included is dxf file in mm's..the 2 objects were drawn 1st then the hatch patterns applied..
Cheers
John
That's interesting John. I created a circle at 0,0 and hatched with gravel. Fine. I then created a block of this and inserted that block way up at 10100, 10000. That inserted block was just fine. I then exploded that block and, yup, shows the inaccuracy as you demonstrate. Would it be worthwhile to suggest an additional option for hatch origin in the hatch dialog - that option being "Center of Selection"?? If the selection is an unusual shape then have it center of the extremities?
Thanks for your continued support.
Hugh
Windows 10
Post by CVH » Sun Feb 23, 2020 2:32 pm
CVH wrote:
Mon Jan 20, 2020 1:55 am
In that we agree, I think it would be a standard notice or even a default behavior when 'hatching'.
It will be one of the proposals if we get that far.
John Hyslop
Post by John Hyslop » Sat Mar 07, 2020 11:56 pm
Cheers
You should put in a feature request..
Best regards
John
