ordinate dimension origin
ljbuller
Post by ljbuller » Sat Sep 14, 2019 5:57 pm
Is there any way to set the 0,0 point of an ordinate dimension other than moving all entities?
Re: ordinate dimension origin
Post by Husky » Sat Sep 14, 2019 6:20 pm
No.
Edit:
Maybe this experimental Add-on/Plug-in is useful for you. It has a "UCS Set origin point" command ...
viewtopic.php?f=107&t=5067&p=18700&hili ... ero#p18700
... but that is not part of the current QCAD Version. :wink:
Post by andrew » Sat Sep 14, 2019 10:37 pm
Yes, you can select the ordinate dimension and drag and drop it's origin to another coordinate or use the property editor to change the property Origin X/Y.
Both methods work for a single or multiple ordinate dimensions.
