Low resolution for dwg2bmp QCAD Command Line
Yon
Post by Yon » Wed May 22, 2019 4:19 pm
I am trying to export a dwg file into a bmp file with the command line tool.
The resault is in a very low resolution.
Is there an extra command that i am missing?
Here is my code:
 D:\Program Files\QCAD>dwg2bmp -f D:\bazelet\villar\villar_samples\180.dwg
File is attached.
Thanks!
Jonatan.
180.dwg
(572.42 KiB) Downloaded 77 times
Re: Low resolution for dwg2bmp QCAD Command Line
Post by andrew » Wed May 22, 2019 4:28 pm
Please refer to our web site at:
https://qcad.org/en/products/qcad-comma ... ls#dwg2bmp
You can set the resolution or the bitmap size (width / height).
