DXF to G code
Sam Rinaudo
DXF to G code
Post by Sam Rinaudo » Tue Feb 19, 2019 10:51 am
Hello
My name is Sam and I am new to Q cad cam. I have just purchased a Stepcratf 840 CNC router.
I have been able to do some cad drawings but I have been having trouble converting them to G code.
Would you help me get started.
Thank you
Sam
Clive
Moderator / Drawing Help
Re: DXF to G code
Post by Clive » Tue Feb 19, 2019 11:00 am
Hello Sam,
Welcome to the forum, it's great to hear that you have chosen QCAD/CAM to work with.
Please elaborate and explain some more specifics on what you need help with in the QCAD/CAM forum section.
Regards
Clive
Re: DXF to G code
Post by andrew » Tue Feb 19, 2019 11:15 am
A good place to start is the QCAD/CAM tutorial at:
https://qcad.org/doc/qcadcam/QCADCAM_Tutorial_en.pdf
This will walk you through the process of adding tools, creating toolpaths and creating G-Code.
For any follow-up question, please let us also know what system you are on (Windows, macOS, Linux) and what controller you are using (e.g. WinPC-NC, UCCNC, etc.).
Sam Rinaudo
Re: DXF to G code
Post by Sam Rinaudo » Mon Feb 25, 2019 11:57 am
Thank you
I am working through the tutorial and will come back to you.
