Shortcut key to close print preview?
lphilpot
Post by lphilpot » Sun Dec 16, 2018 5:43 pm
Is there a way to close Print Preview with the keyboard? I haven't found one, but I may be overlooking it. If it doesn't conflict with something else, Esc would be nice.
QCAD 3.21.3.0 on Xubuntu 16.04, 64-bit, if it matters
Thanks.
Len
Re: Shortcut key to close print preview?
Post by Husky » Mon Dec 17, 2018 8:42 am
On Win and Mac it supposed to work with Ctrl+Q and ⌘Q. But it is broken .... :cry:
TSG
Post by TSG » Mon Dec 17, 2018 8:48 am
I don't know how it is on Xubuntu but on macOS you can change the preview back to normal view by just repeating the command for print preview (SHIFT+CMD+P).
lphilpot
Post by lphilpot » Mon Dec 17, 2018 7:34 pm
Ctrl+Q quits QCAD, but Ctrl+Shift+P does in fact toggle Print Preview, not just activate it.
Thanks.
Len
Post by Husky » Mon Dec 17, 2018 8:02 pm
Ctrl+Q quits QCAD ...
Yep - my bad! I misinterpreted the Shortcut List. Sorry for that!
Ctrl+Q will close something else but to close QCAD on Win it has to be Alt+F4.
I agree - Esc or QQ would be a suitable Shortcut to close the Preview and unfortunately we have no chance to change the settings by ourself below "Tool Settings" :(
Rantanplan7
Post by Rantanplan7 » Wed Dec 19, 2018 3:53 pm
If I get you right you are searching for CTRL+Shift+P which takes you to print preview and back as well.
Best Regards
Sven
QCAD 3.24.2 / Windows 10 Professional 64-bit / 8 GB RAM, i5 [email protected], SSD
(former Autosketch 10 user)
