I run QCADCAM-Pro 3.4.6 on openSUSE 13.1 KDE 4.12.4
uname -a
Linux PVE-LinuxSRV5 3.11.10-9.gdf9697b-desktop #1 SMP PREEMPT Wed Jan 8 15:41:04 UTC 2014 (df9697b) x86_64 x86_64 x86_64 GNU/Linux
The issue I am seeing is related to opening files.
- If I navigate to a file.dxf in Dolphin (KDE file manager), then right click on it and select Open With: qcad, all is well
If I start qcad with ./qcad from the install directory, or if I start it from the GUI (using a customized qcad.desktp file),then chose File-Open Recent and select from the list, file.dxf opens OK
If I start qcad with ./qcad from the install directory, or if I start it from the GUI (using a customized qcad.desktp file), then choose File-Open, a file browser opens (I believe this is called the kde file chooser interface), I can navigate my file system to a file, I left click on a file , which normally would select it, the file chooser window closes but no file gets opened in QCADCAM.
./qcad
Debug: RCamScriptsPlugin: init
Debug: RDxfPlugin::init
Debug: RHelpPlugin::init
Debug: RProScriptsPlugin::init
Debug: TIMER: 77 ms - "loading add-ons"
Debug: TIMER: 772 ms - "initializing add-ons"
Debug: RPluginBase: postInit: "CAM"
Debug: RPluginBase: postInit: "DWG"
Debug: RPluginBase: postInit: "Pro Tools"
[b]Warning: KGlobal::locale(): Warning your global KLocale is being recreated with a valid main component instead of a fake component, this usually means you tried to call i18n related functions before your main component was created. You should not do that since it most likely will not work
Warning: Object::connect: No such signal org::freedesktop::UPower::DeviceAdded(QDBusObjectPath)
Warning: Object::connect: No such signal org::freedesktop::UPower::DeviceRemoved(QDBusObjectPath)[/b]((Hmmm, color and bold highlighting not working in code window?))
I tried similar CLI starups with gimp and inkscape, but thesy seem to use a differnt file chooser interface (I believe called the qT file chooser)
QCAD seems to use the KDE chooser (via KDE integration), so I tried a know KDE App with these results
> gwenview
Object::connect: No such signal org::freedesktop::UPower::DeviceRemoved(QDBusObjectPath)Note the same two "No such signal" warnings, but no complaint about " KGlobal::locale().."
I plan to take this issue to the openSUSE forum as well, but expect a request I check with the application author.
Any thoughts from your end?
