Inside Hatches, more than meets the eye
Panchdara
Senior Member
Re: Inside Hatches, more than meets the eye
Post by Panchdara » Sun Feb 23, 2020 9:37 am
John Hyslop wrote:
Fri Feb 14, 2020 11:06 pm
Hi CVH
I've given users the wrong information... I said to set the origin to X0Y0 on objects far from drawing datum
I should of said set Hatch origin to object datum.... see screenshot example of GRAVEL Hatch Pattern.. also
included is dxf file in mm's..the 2 objects were drawn 1st then the hatch patterns applied..
Cheers
John
That's interesting John. I created a circle at 0,0 and hatched with gravel. Fine. I then created a block of this and inserted that block way up at 10100, 10000. That inserted block was just fine. I then exploded that block and, yup, shows the inaccuracy as you demonstrate. Would it be worthwhile to suggest an additional option for hatch origin in the hatch dialog - that option being "Center of Selection"?? If the selection is an unusual shape then have it center of the extremities?
Thanks for your continued support.
Hugh
QCAD 3.24.3 / Windows 10 x86_64
Post by CVH » Sun Feb 23, 2020 2:32 pm
CVH wrote:
Mon Jan 20, 2020 1:55 am
In that we agree, I think it would be a standard notice or even a default behavior when 'hatching'.
It will be one of the proposals if we get that far.
John Hyslop
Post by John Hyslop » Sat Mar 07, 2020 11:56 pm
Cheers
You should put in a feature request..
Best regards
John
