PDF exports with bigger lineweights than showed in layout
dfriasb
Senior Member
Post by dfriasb » Fri Jan 10, 2020 11:27 am
Dear all,
When I export a Layout to PDF lines are showed with huge lineweight. This seems to start happenning after installing last version of QCAD Pro 3.24.0.0 (3.24.0).
I attach dxf file, PDF (result os PDF export of Layout1 block), and screenshot showing how I see layout in my screen (showing lineweights).
Screenshot from 2020-01-10 11-18-22.png (338.97 KiB) Viewed 3941 times
cad.pdf
(1.97 MiB) Downloaded 397 times
cad.dxf
(345.33 KiB) Downloaded 388 times
Re: PDF exports with bigger lineweights than showed in layout
Post by andrew » Fri Jan 10, 2020 2:48 pm
dfriasb
Senior Member
Post by dfriasb » Fri Jan 10, 2020 3:22 pm
Thanks Andrew,
:idea: My temporary solution is enlarging drawings into layouts, so line thickness becomes bigger than 0.01 units.
Post by andrew » Mon Jan 13, 2020 1:52 pm
This should be fixed in QCAD 3.24.2.
dfriasb
Senior Member
Post by dfriasb » Mon Jan 13, 2020 6:23 pm
It's solved!
