Remove Test Program .
Ned Kelly
Post by Ned Kelly » Fri Nov 08, 2019 6:59 am
I have installed the test program on a Linux x64 bit system Ubuntu 14.04. And it works well, however I understand it should be removed before installing the purchased version. This I am having trouble doing as I installed it by copy and paste and have no idea where the program files are, their name etc to allow me to remove them, can someone help please ?
Re: Remove Test Program .
Post by andrew » Fri Nov 08, 2019 8:35 am
QCAD installs under ~/opt, that's for example /home/ned/opt/qcad-3.23.0-pro-linux-x86_64 if your user name is "ned". All files are installed into one single folder. To uninstall, simply remove that folder.
Ned Kelly
Post by Ned Kelly » Sat Nov 09, 2019 3:14 am
Solved !, thanks Andrew, easy instructions, worked perfectly
