Add new layer - minor issue
Panchdara
Post by Panchdara » Sun Apr 14, 2019 8:25 am
Create new drawing.
Add new layer (Layer 1)
Layer 0 still selected but entities drawn on Layer 1
Windows 10
Re: Add new layer - minor issue
Post by Husky » Sun Apr 14, 2019 4:35 pm
Good to know, thanks!
Please file a bug report below https://www.ribbonsoft.com/bugtracker
Panchdara
Post by Panchdara » Sun Apr 14, 2019 5:18 pm
I hate being the "tattle-tail"! :evil: :mrgreen:
Will do.
Best
Windows 10
Panchdara
Post by Panchdara » Mon Apr 15, 2019 6:29 pm
THANK YOU 3.22.0.7
Bestest
Hugh
Windows 10
Panchdara
Post by Panchdara » Mon Apr 29, 2019 7:04 am
Layers issue has returned. Add new layer and the new layer, even though active, is not highlighted although the pencil icon shows. And in some cases no layers are highlighted after the new layer is added or the wrong layer is highlighted. 3.22.09
Windows 10
Post by andrew » Mon Apr 29, 2019 9:22 am
The 'highlighted' (blue background) layer is irrelevant starting with 3.22.0.9. The pen icon shows which layer is active and used to draw upon.
This is because multiple layers may be selected, deleted or edited (Shift / Ctrl).
As usual with snapshots, all this is highly experimental. The latest stable release is 3.22.0.
Panchdara
Post by Panchdara » Mon Apr 29, 2019 9:31 am
Thanks Andrew. Yeah, the blue background threw me a sec then. I did notice the pencil icon. I'll keep that in mind. All good otherwise (from what I do use).
Best
Windows 10
