Windows 10 x64
QCAD 3.22.0
Brain stuck-infinite loop (autocad trim/extend function)
1.) How do I remove line segments between two intersections ?
I know in autocad it would be trim, and then I would select the entities I would cut from, enter, then select the discard section to remove it.
I just could not bring myself to using freehand draw to create a break spot. I tried, but it was quite ugly. So I am trying to create it as I have done before by creating a break line, parallel copy, trim remove the between segment
[solved] Removing line segment between two intersections
- QCAD Break Trim.docx
- (276.4 KiB) Downloaded 365 times
- EX9.12 Break Trim Extend.dxf
- (102.5 KiB) Downloaded 380 times
Re: Removing line segment between two intersections
Launch Modify / "Break out segment" and click on the line which needs to be removed.
Right in front of me the whole time, and easier. Thank You Kindly.
