scripts folder is empty
laschishin
Post by laschishin » Wed Mar 13, 2019 3:48 pm
I have 3.22.0 version installed.
This version doesn't contains c:\Program Files\QCAD\scripts\ subfolders and scripts (for example, c:/Program Files/QCAD/scripts/Layer/Layer.js).
I know that version 3.16.5 contains such scripts.
I need those scripts in my work.
How can I solve this problem?
Simple comying all conent of script folder from 3.16 to 3.22 didn't helped. QCAD don't starts after this.
Thanks!
Re: scripts folder is empty
Post by andrew » Wed Mar 13, 2019 4:04 pm
Please have a look at c:\Program Files\QCAD\scripts\readme.txt
