Change in Parallel with Distance
bryank99
Post by bryank99 » Mon Apr 23, 2018 2:39 pm
Hi Andrew,
In previous versions the Distance dialog box kept focus while drawing, so one could simply type a new offset without having to set focus to Distance for each change. This was most useful while drawing lines with different offsets rapidly.
Now in V 3.20.1 0, this no longer works. Was this change intentional?
Bryan
Re: Change in Parallel with Distance
Post by andrew » Mon Apr 23, 2018 2:48 pm
You can simply type a new distance while using this tool (even if the distance input field does not have the keyboard focus).
J-J
Moderator
Post by J-J » Mon Apr 23, 2018 6:46 pm
thanks for the tip, I never realized we could do it that way :)
JJ Win7 pro-64
Return to “Chat”
