Colors in QCAD?
GUS
Colors in QCAD?
Post by GUS » Tue Nov 21, 2017 8:22 pm
Hi - I am new to QCAD (been using an old Visio 5.0 (1997) CAD program). In looking over the QCAD user interface & reading the User Ref Manual, I find no mention of colored lines or adding color infill to shapes or blocks. Does QCAD provide for colored dwgs??
Thanks, Gus
J-J
Moderator
Re: Colors in QCAD?
Post by J-J » Tue Nov 21, 2017 8:37 pm
Hello GUS
Welcome to the forum, the place for all (or most) answers :wink:
Colors in QCAD are handled through layer properties: create a layer for each color or line characteristic you want
color handling.jpg (118.15 KiB) Viewed 4027 times
JJ Win7 pro-64
Re: Colors in QCAD?
Post by Husky » Tue Nov 21, 2017 9:35 pm
GUS wrote:... or adding color infill to shapes ...
The active layer is also responsible to infill shapes. Just check "Fill" and it's done ... :wink:
Return to “Chat”
