What do people use QCAD for?
Re: What do people use QCAD for?
Hi all
I am using Qcad for several task: one is to redo all my drawings done in Excel of my house renovation into proper layered technical drawings, I also use it to produce drawings of profiles that can be made on a router table as library components which can then be assembled in a drawing in order to visualise the finished product and anything else that I want to keep accurate data for, remember a drawing can replace a thousand words.
all the best Roy
all the best Roy
- DaysonPrio
- Newbie Member
I work in the field of 2D and 3D architectural design, mainly with AutoCAD and Artec software.
It looks like I'm not the only one who tried LibreCAD at first and switched to QCAD then. And I have to say I'm glad about a more polished drawing interface, a dark theme of the program and I am happy with the expanding feature set. Well done, thanks for your work.
Best regards.
Best regards.
I use have used autocad 2010 LT and have previously used R14 to generate architectural submittal drawings for div 8 and 10 materials ranging from toilet compartments, HM frames, Cubical curtains, room signage, and such for the better part of 30 years. I am trying to transition to QCAD to fulfill that need. I have tried LibreCad, BRL cad, TurboCad etc and have found them all lacking. The only thing I struggle with on QCAD is the learning curve to accomplish the same goal I achieve with Autocad. The functionality is there, the staff support is there, It is just a personal learning curve of differences between the two. I am excited about learning QCAD as I feel it is equal or surpassing autocad. I will just be a needy fellow in the forum until I grasp the differences and nuance of qcad
I am using QCAD for drawings schematics of rainwater harvesting systems.
I'm not -- and have never been -- a CAD pro* but have used QCAD at home for about four years. For anything above a trivial level, it's easier to draw it up in QCAD than by hand. The hardest part is remembering what I forgot since the last time I used it!!
* In my first career I used vector-based illustration software as a graphic designer (CorelDRAW, etc.) before moving to IT 24 years ago (now retired!). Although not CAD, there's the possibility of a similarly-disciplined approach and a bit of overlap in terms of the ability to be precise and repeatable.
Here's a sample - I drew up the primary mirror cell (i.e. holder) from my 12" Dobsonian style astronomical telescope. I'm evaluating modifying the cell a bit and quantifying where it is now in QCAD makes possible modifications clearer. This drawing isn't complete in all aspects, but it's just for me and I know what bits are missing. Fortunately I'm not held to any corporate nor industry standards!
Len
QCAD Pro
QCAD Pro
I have been a QCAD user for something over 12 years. Mostly for personal use in my wood shop. Heaviest use was during 2008 when I remodelled our kitchen and building the cabinets. Wish I could have generated a cut list!
- kitchen.dxf
- (1.08 MiB) Downloaded 1218 times
- Papy Octet
- Full Member
Bonjour.
J'utilise QCad pour de nombreuse action : dessiner les plans de petites constructions en bois pour mes petits-enfants (reproduction de jouets anciens).
Mais mon utilisation principale concerne le dessin de patrons de tissage pour la dentelle aux fuseaux en association avec Inkscape
A+
A+
Debian 10 - Qcad-Prof 3.19.0.0
I am running Qcad 3.27.7 on Windows 11
My business is CNC fabricating aluminum instrument panels for aircraft.
I use Qcad for the panel layouts and then feed the output DXF file to the CAM software that generates the tool paths for my CNC machine.
Bill from Vermont - USA
good evening, I use qcad professional for importing files from customers. Files are prepared and analyzed for export to my cam section to run a big cnc milling machine that cuts the carbon plates we are producing. I‘m new into this program but I already like it and also I like this forum
- IMG_2702.jpeg (3.79 MiB) Viewed 47982 times
- 52295f5b-9bf1-4b23-bb14-901175216925.jpeg (122.48 KiB) Viewed 47982 times
- IMG_3046.jpeg (3.26 MiB) Viewed 47982 times
- IMG_3050.jpeg (3.65 MiB) Viewed 47982 times
- IMG_3051.jpeg (2.87 MiB) Viewed 47982 times
