change grid to 1/8" and 1 ft?
How do I set up the grid to have minor at 1/8" and major at 12", i.e. x = ?? and y = ??.
Re: change grid to 1/8" and 1 ft?
For the actual drawing below Menu / Edit / Drawing Preferences:
For all new drawings below Menu / Edit / Application Preferences.
Please make sure that your drawing unit is set to inch - you will find it in the already mentioned dialog.
Thanks Husky, that was too easy.
btw, love the avatar, I use to raise Samoyeds
