I have been problem with my First screen of program. I unset the screen. I will atache two images for better understanding. Please , help me if possible. Sorry, I have no experience with QCAD.
Layers list
Brock list
(solved) Repair in screen
- Active Member
- Wrong screen
- IMG_20200511_142944059.jpg (4.52 MiB) Viewed 3726 times
- Correct screen
- Screenshot_20200511-164548.png (512.97 KiB) Viewed 3726 times
Re: (solved) Repair in screen
What seems to be the problem?
Can you elaborate on that?
- Active Member
Morning,
I will try to explain:
In the main screen, appear two windows, layers list and block list together on the right.
Unfortunatily I unset anything , and the windows layers list and block list appear at the time, no more like main screen, together. Now they appear separated;( at the time), but I am working Very well.
Sorry, long time no use English.
Regards
Regards
Those panels we call 'Widgets'.
Apart from that there are numerous 'Toolbars'.
The visibility of those can be altered in several ways.
One would be: Menu .. View .. Toolbars and Widgets (at the bottom).
