Rescale // Print Preview problem
Bebbspoke
Post by Bebbspoke » Mon Mar 16, 2020 3:59 pm
Hi Peoples - "idiot" newbie here... I use Viewport to rescale a drawing (where 1"=28") fits nicely on to a landscaped A4 Preview.
However; - the X & Y Offsets required are negative values
All attempts to centre the dwg result in "syntax errors" ... please, any suggestions?
Where's the old fool going wrong??? Thank you.
Re: Rescale // Print Preview problem
Post by Husky » Mon Mar 16, 2020 6:36 pm
please help me to understand what you are doing. You are talking about Viewports in QCAD Community Edition. The QCAD CE edition has no Viewports ...
Would it be possible to attache the drawing. Thanks.
