I have imported a drawing from Qcad into Blender and in one place a little line appears that definitely does not appear in the Qcad drawing.
This little line segment in the circle doesn't belong there. Could it be in another layer? The BLender DXF import possibly throws everything into one layer.
Drawing contains some invisible "smudge"
Christoph
Christoph
Re: Drawing contains some invisible "smudge"
It's impossible for us to answer that question without the dxf. Please attache the drawing to the post. Thanks.
I thought so Will try to attach it here.
- shape_1.dxf
- (41.17 KiB) Downloaded 455 times
Christoph
Christoph
Thanks.
Well, more than obviously it is part of the QCAD drawing .....
Strange. I didn't see it on the screen(see screenshot) Did a "SAVE" before uploading.
Maybe an icloud/cache issue? Gotta get rid of that iCloud drive.
Sorry for the confusion.
Christoph
Christoph
