Associative hatches?
Posted: Fri Nov 10, 2017 9:25 pm
by lphilpot
Does QCAD support associative hatches? Or is there another technique to (effectively) resize a hatch, e.g., after stretching a hatched entity?
I thought I saw this question somewhere on the forums, but no amount of searching turned it up. I also searched the website for hatch and associative but found nothing (unless it's called something else).
Thanks!
Re: Associative hatches?
Posted: Fri Nov 10, 2017 11:59 pm
by Husky
Yes and no ...
If you use the Stretch tool on a hatched shape then the hatch will follow the new shape. If you use a rotation or scale tool then it will have also an (unwanted?) effect on the hatch. To fix that the Property Editor is your best friend ...
BTW: I would always recommend to put all hatches on a separate "Hatch Layer". Makes your life easier in the long run ...
Posted: Sat Nov 11, 2017 12:29 am
by lphilpot
That's why I asked...
I had drawn a test rectangular shape on one layer, added a hatch on another, selected both and stretched them, but only the lines stretched. The hatch remained the same shape and size. That made me wonder.
But I just tried it again and this time it worked. Obviously I did something wrong before, although I'm not sure what it was. Maybe I didn't have the hatch selected, but both times I used a window selection and encompassed everything.
As as test, I window-selected the four lines and hatch, verified all were shown in the property editor, deselected the hatch only (used Shift+click), verified again and stretched the selection. The hatch stretched as well.
No idea what I did wrong before, but it's working now!
Thanks!
Posted: Sat Nov 11, 2017 2:03 am
by Husky
lphilpot wrote:... but it's working now!
Glad to hear that. Just keep in mind that an operation like this involves two not connected objects. The shape and the hatch ...
- Husky-2017.11.10-01.png (10.38 KiB) Viewed 6266 times
... and the Reference points are overlaid.
