How to get past the "Transaction failed..." error
copyrightx
Post by copyrightx » Fri Jun 12, 2015 5:02 am
So most everything I try to do with the attached file fails with the error message: "Transaction failed. Please check for block recursions and locked or invisible layers or blocks."
I don't know how I got this document into this state, but it wasn't through anything very sophisticated. Can anyone tell me how to fix this document so that I can continue developing it? I can't get the application to respond as expected to any command I have tried, from L,A to D,A or most anything.
test.dxf
Try doing a L,A command in this document. Fails as indicated in post.
(65.53 KiB) Downloaded 583 times
copyrightx
Re: How to get past the "Transaction failed..." error
Post by copyrightx » Fri Jun 12, 2015 5:04 am
Using QCAD 3.9.1.0 (3.9.1) with Qt Version: 4.8.6 from an Arch Linux built-in package.
Post by andrew » Fri Jun 12, 2015 7:31 am
The crucial hint in the error message is about locked and invisible layers. Most of your layers are locked and / or invisible. If a layer is locked or invisible, it cannot be modified and you cannot draw on it.
A layer is locked if the lock symbol beside it is black. You can unlock / lock layers by clicking on that lock symbol:
Screen Shot 2015-06-12 at 08.29.12.png (37.59 KiB) Viewed 11365 times
A layer is invisible if the eye symbol beside it is gray. You can make it visible / invisible by clicking on that eye symbol.
copyrightx
Post by copyrightx » Fri Jun 12, 2015 1:11 pm
Wow, big help. Thank you very much. Even more important, your reply helped me discover how I locked all of my layers: while trying to use hot-keys to select the length of a line that I was about to draw with a just-issued [L]ine, [A]ngle command, I used the Alt+L key combination. The first time I did so, I dropped the Layer menu down (not what I wanted). Then thinking that another Alt+L key combination would select the length of the line, I (now see that the second Alt+L key combination) locked all my layers :( . The third Alt+L key combination did finally select the length that I wanted to select, but I didn't notice the padlocks in the layers tab appearing with the second Alt+L.
What's the best way to be able to use hot-keys for selecting that Length field without locking all my layers on the way to doing that?
And what's that Defpoints Layer in your image above? I don't see that in my drawing...
massimo
Post by massimo » Sun Nov 19, 2017 3:39 pm
I have the same error message when trying to delete a layer. I also tried toggling the visibility via context menu. In the context menu there is no item about locking a layer.
I can't see those icons for each layer to toggle visibility and locking. There is only the layer name.
My current build is the very latest version from the repo:
Version:
3.19.1.0 (3.19.1)
Internet:
QCAD.org
Build Date:
Nov 19 2017
Revision:
Qt Version:
4.8.7
Architecture:
x86_64
Compiler:
gcc 6.4.0
Community Version 3.28.2.0, Gentoo Linux on amd64
