Change tool
Change tool
Does Qcad.Cam incorporate change tool command, I seen the M6 in the Gcode, but it seems to skip over that command and function.
Re: Change tool
QCAD/CAM typically outputs something like:
Where 1 is the tool number.
For Mach3, you might need something like:
Where G28 moves to the home position. The "1" in T1 and H1 is the tool number. G43 means to apply offsets.
Could you try the above code by editing the G-Code output by QCAD/CAM? If you can confirm this, I will adjust the post processor accordingly, thanks.
You can find some more information about this on youtube at:
https://www.youtube.com/watch?v=0cM32grBMvo
N10 T1 M6
N10 G28
N20 T1 M6 G43 H1
Re: Change tool
Thank You that was helpful.
Re: Change tool
Something I forgot to mention, in order for that to work, you need to go to Mach3. At the top go, Config> General Logic Config>Tool Change and click on "Stop Spindle. Wait for Cycle Start". If it is on "Ignore Tool Change" the function won't work.
