Camexporter request
srl
Camexporter request
Post by srl » Mon May 02, 2016 12:41 am
Hi Andrew
I'm working on a better config.
I found the line
simEntity.setColor(RColor.isByLayer());
in exportLineSegment(). Its not in exportArcSegment().
Can it be removed as it limits the createLayer function.
Could the following be changed in createLayer to allow for linetypes?
Test1.prototype.createLayer = function(layerName, color, lineType) {// change
	if (lineType == null)// change
		lineType = "continuous";// change
    var layerId = this.newDocument.getLayerId(layerName);
    if (layerId!==RObject.INVALID_ID) {
        return layerId;
    var layer = new RLayer(
        this.newDocument,
        layerName,
        false, false,
        color,
        this.newDocument.getLinetypeId(lineType),// change
        RLineweight.Weight000
    var op = new RAddObjectOperation(layer);
    this.newDocumentInterface.applyOperation(op);
    return this.newDocument.getLayerId(layerName);
srl
Re: Camexporter request
Post by andrew » Mon May 02, 2016 9:25 am
Looks good, thanks.
BTW: you can override all these functions in your own configuration for now to get that functionality immediately, before the next update.
srl
Post by srl » Thu Jun 09, 2016 9:21 am
Hi Andrew
Could I have the following line types added to QCad?. It would save me entering them in with each new release.
They are half "Drainage" to show a offset cut in Cam preview using the above code changes.
To use offset line types in the qcad-cam preview add the following lines to a file and place it in the Qcad/linetypes/metric/ directory-
*CUTLEFT,G41 ----\----\----\----
A,5.08,[LRIGHT_ARROW,qcadshp.shx,S=2.54,R=180],5.08
*CUTLEFT2,G41 reversed----/----/----/----
A,5.08,[LRIGHT_ARROW,qcadshp.shx,S=2.54],5.08
*CUTRIGHT,G42 ----/----/-----/---
A,5.08,[HRIGHT_ARROW,qcadshp.shx,S=2.54,R=180],5.08
*CUTRIGHT2,G42 reversed----\----\----\----
A,5.08,[HRIGHT_ARROW,qcadshp.shx,S=2.54],5.08
Also add the following to the /fonts/qcadshp.cxf file leaving a line space between each group of lines-
[0090] HRIGHT_ARROW
L 1,0.5,0,0
[0091] LRIGHT_ARROW
L 0,0,1,-0.5
srl
Post by andrew » Fri Jun 10, 2016 10:24 am
OK, I'll add these to the next QCAD/CAM release (linetypes in file linetypes/metric/qcadcam.lin).
srl
Post by srl » Tue Jun 14, 2016 1:16 am
Thanks for the line additions Andrew.
It looks great. :D
Screenshot from 2016-06-14 07-32-27.png (50.65 KiB) Viewed 9829 times
srl
