32b,Win7, QCAD2.2.2.0.
Can not use drop down FILE menu to SAVE, SAVE AS, or OPEN, PC hangs up. Please advise.
QCAD hang
Re: QCAD hang
mr.riggmr.rigg wrote:32b,Win7, QCAD2.2.2.0.
Hi and Welcome to the forum
Can you use any other menu options e.g. View or Edit or any Tool commands without problems?
If this is first time install, if it was me I think I would try a re-install and try a different directory!
See if that works.
- Registered Member
Left mouse button without function.
32b, Win7, QCAD 2.2.2.1
Same problem occurs with my installation. Left mouse button seems to be without function. Drop down menues are working only by using Alt and any keyboard click. I tried reinstall in a different directory, but without success.
Werner
Werner
