Hi guys,
Iam wondering. Are there any issues after the upgrade to MacOs Ventura? Is Qcad still working smoothly, or are there any problems? Can you let me know before I upgrade? Thank you.
Regards
Radek
Any issues after upgrade to MacOs Ventura?
- ryancousins
- Premier Member
Re: Any issues after upgrade to MacOs Ventura?
After playing around for just a short time with QCAD 3.27.8 on Ventura, I've had no issues. If that changes I'll let you know.
Thanks for your reply. I think I can upgrade also.
It is crashing when opening dwg or dxf files, when inserting pictures and spontaneously too on MAC Ventura for me...
Here is the apple crash log:
Translated Report (Full Report Below)
Process: QCAD-Pro [36505]
Path: /Applications/QCAD-Pro.app/Contents/MacOS/QCAD-Pro
Identifier: org.qcad
Version: 3.27 (3.27.6)
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2022-12-19 15:25:41.3255 +0900
OS Version: macOS 13.1 (22C65)
Report Version: 12
Anonymous UUID: 29701D90-97DB-1E76-C2C8-341CB6F1FE3F
Sleep/Wake UUID: ABAF0454-CC18-4C6A-802F-83D23029CD96
Time Awake Since Boot: 91000 seconds
Time Since Wake: 4890 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [36505]
VM Region Info: 0 is not in any region. Bytes before following region: 4374822912
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 104c28000-104c38000 [ 64K] r-x/r-x SM=COW ...acOS/QCAD-Pro
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 QtScript 0x105c75b74 0x105c2c000 + 301940
1 QtScript 0x105c759e8 0x105c2c000 + 301544
2 QtScript 0x105c798a0 0x105c2c000 + 317600
3 QtScript 0x105cab650 0x105c2c000 + 521808
4 QtScript 0x105d1cb34 QScriptValue::call(QScriptValue const&, QList<QScriptValue> const&) + 628
5 libqcadecmaapi.dylib 0x106b060fc REcmaShellViewFocusListenerAdapter::updateFocus(RGraphicsView*) + 576
6 libqcadcore.dylib 0x105645224 RMainWindow::notifyViewFocusListeners(RGraphicsView*) + 356
7 libqcadgui.dylib 0x104d99520 RGraphicsViewQt::focusInEvent(QFocusEvent*) + 304
8 QtWidgets 0x107dbea84 QWidget::event(QEvent*) + 988
9 QtWidgets 0x107d894b0 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 292
10 QtWidgets 0x107d8a844 QApplication::notify(QObject*, QEvent*) + 556
11 QtCore 0x1095987e0 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 208
12 QtWidgets 0x107d8733c QApplicationPrivate::setFocusWidget(QWidget*, Qt::FocusReason) + 380
13 QtWidgets 0x107dba7d0 QWidget::setFocus(Qt::FocusReason) + 604
14 QtWidgets 0x107d8856c QApplication::setActiveWindow(QWidget*) + 1012
15 QtWidgets 0x107d88970 QApplicationPrivate::notifyActiveWindowChange(QWindow*) + 52
16 QtGui 0x1088b5b3c QGuiApplicationPrivate::processActivatedEvent(QWindowSystemInterfacePrivate::ActivatedWindowEvent*) + 612
17 QtGui 0x10889a3b0 void QWindowSystemInterface::handleWindowActivated<QWindowSystemInterface::SynchronousDelivery>(QWindow*, Qt::FocusReason) + 168
18 libqcocoa.dylib 0x107ba0a5c 0x107b80000 + 133724
19 QtCore 0x1095a2fa0 QMetaMethod::invoke(QObject*, Qt::ConnectionType, QGenericReturnArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument) const + 976
20 libqcocoa.dylib 0x107ba408c 0x107b80000 + 147596
21 CoreFoundation 0x1a1a3155c __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 128
22 CoreFoundation 0x1a1acf054 ___CFXRegistrationPost_block_invoke + 88
23 CoreFoundation 0x1a1acef9c _CFXRegistrationPost + 440
24 CoreFoundation 0x1a1a02b74 _CFXNotificationPost + 708
25 Foundation 0x1a28f072c -[NSNotificationCenter postNotificationName:object:userInfo:] + 88
26 AppKit 0x1a4e124bc -[NSWindow becomeKeyWindow] + 804
27 AppKit 0x1a4db7718 -[NSWindow _changeKeyAndMainLimitedOK:] + 748
28 AppKit 0x1a549ceac -[NSWindow _orderOut:calculatingKeyWithOptions:documentWindow:] + 884
29 AppKit 0x1a4cff528 NSPerformVisuallyAtomicChange + 108
30 AppKit 0x1a549e55c -[NSWindow _reallyDoOrderWindowOutRelativeTo:] + 488
31 AppKit 0x1a549e8a8 -[NSWindow _reallyDoOrderWindow:] + 80
32 AppKit 0x1a560ff4c -[NSSavePanel _reallyDoOrderWindow:] + 56
33 AppKit 0x1a549eaf8 -[NSWindow _doOrderWindow:] + 264
34 AppKit 0x1a560e398 -[NSSavePanel completeWithReturnCode:url:urls:] + 448
35 AppKit 0x1a560c9b4 -[NSSavePanel observeMostRecentCompletion:] + 464
36 AppKit 0x1a560c4a8 -[NSSavePanel observeValueForKeyPath:ofObject:change:context:] + 404
37 Foundation 0x1a291a3c4 NSKeyValueNotifyObserver + 252
38 Foundation 0x1a29ca280 NSKeyValueDidChange + 360
39 Foundation 0x1a2eb39f0 NSKeyValueDidChangeWithPerThreadPendingNotifications + 160
40 ViewBridge 0x1a95dd700 __47-[NSViewBridge setObject:forKey:withKVO:local:]_block_invoke + 300
41 ViewBridge 0x1a9660200 withHintInProgress + 168
42 ViewBridge 0x1a95dd440 -[NSViewBridge setObject:forKey:withKVO:local:] + 532
43 ViewBridge 0x1a963fe74 -[NSRemoteViewMarshal setHostObject:forKey:] + 264
44 CoreFoundation 0x1a1a1edc4 __invoking___ + 148
45 CoreFoundation 0x1a1a1ec3c -[NSInvocation invoke] + 428
46 ViewBridge 0x1a95d4bb4 __deferNSXPCInvocationOntoMainThread_block_invoke + 132
47 ViewBridge 0x1a95c9d44 __wrapBlockWithVoucher_block_invoke + 56
48 ViewBridge 0x1a965ef6c kNotRunningOnAppKitCompatibleThread_block_invoke + 360
49 CoreFoundation 0x1a1a3c5b0 __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 28
50 CoreFoundation 0x1a1a3c4c4 __CFRunLoopDoBlocks + 368
51 CoreFoundation 0x1a1a3b970 __CFRunLoopRun + 2452
52 CoreFoundation 0x1a1a3a888 CFRunLoopRunSpecific + 612
53 HIToolbox 0x1ab10ffa0 RunCurrentEventLoopInMode + 292
54 HIToolbox 0x1ab10fde4 ReceiveNextEventCommon + 672
55 HIToolbox 0x1ab10fb2c _BlockUntilNextEventMatchingListInModeWithFilter + 72
56 AppKit 0x1a4cbc424 _DPSNextEvent + 632
57 AppKit 0x1a4cbb5b4 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 728
58 AppKit 0x1a4ef5bdc -[NSApplication _doModalLoop:peek:] + 216
59 AppKit 0x1a4ef4aec __35-[NSApplication runModalForWindow:]_block_invoke_2 + 56
60 AppKit 0x1a4ef4a98 __35-[NSApplication runModalForWindow:]_block_invoke + 108
61 AppKit 0x1a4ef437c _NSTryRunModal + 100
62 AppKit 0x1a4ef423c -[NSApplication runModalForWindow:] + 292
63 AppKit 0x1a560b520 -[NSSavePanel runModal] + 340
64 libqcocoa.dylib 0x107bec900 0x107b80000 + 444672
65 libqcocoa.dylib 0x107bf0308 0x107b80000 + 459528
66 QtWidgets 0x107f61b08 QDialog::exec() + 264
67 libqtscript_widgets.dylib 0x1197209dc QtScriptShell_QFileDialog::exec() + 420
68 QtWidgets 0x107f633d4 0x107d78000 + 2012116
69 QtWidgets 0x107f635a8 QDialog::qt_metacall(QMetaObject::Call, int, void**) + 172
70 QtWidgets 0x107f7cf90 QFileDialog::qt_metacall(QMetaObject::Call, int, void**) + 32
71 QtScript 0x105d330e8 0x105c2c000 + 1077480
72 QtScript 0x105d31ad0 0x105c2c000 + 1071824
73 QtScript 0x105d23b50 0x105c2c000 + 1014608
74 QtScript 0x105d23498 0x105c2c000 + 1012888
75 QtScript 0x105c90284 0x105c2c000 + 410244
76 QtScript 0x105c75ac0 0x105c2c000 + 301760
77 QtScript 0x105c6e554 0x105c2c000 + 271700
78 QtScript 0x105d07168 0x105c2c000 + 897384
79 QtScript 0x105d0b0d8 QScriptEngine::evaluate(QString const&, QString const&, int) + 332
80 libqcadecmaapi.dylib 0x1060546b4 RScriptHandlerEcma::eval(QString const&, QString const&) + 44
81 libqcadecmaapi.dylib 0x106055e14 RScriptHandlerEcma::createActionApplicationLevel(QString const&, RGuiAction*) + 644
82 libqcadcore.dylib 0x10568c03c RScriptHandler::triggerActionApplicationLevel(QString const&, RGuiAction*) + 88
83 libqcadcore.dylib 0x105619458 RGuiAction::slotTrigger(QString const&) + 444
84 libqcadcore.dylib 0x10572dd30 RGuiAction::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 168
85 QtCore 0x1095c8b78 0x1093c4000 + 2116472
86 QtWidgets 0x107d80348 QAction::activate(QAction::ActionEvent) + 308
87 QtWidgets 0x107e59694 0x107d78000 + 923284
88 QtWidgets 0x107e5a6dc QAbstractButton::mouseReleaseEvent(QMouseEvent*) + 256
89 QtWidgets 0x107f47adc QToolButton::mouseReleaseEvent(QMouseEvent*) + 20
90 QtWidgets 0x107dbe728 QWidget::event(QEvent*) + 128
91 QtWidgets 0x107f481f8 QToolButton::event(QEvent*) + 280
92 QtWidgets 0x107d894b0 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 292
93 QtWidgets 0x107d8bdec QApplication::notify(QObject*, QEvent*) + 6100
94 QtCore 0x1095987e0 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 208
95 QtWidgets 0x107d89e28 QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) + 988
96 QtWidgets 0x107ddc038 0x107d78000 + 409656
97 QtWidgets 0x107ddb058 0x107d78000 + 405592
98 QtWidgets 0x107d894b0 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 292
99 QtWidgets 0x107d8a844 QApplication::notify(QObject*, QEvent*) + 556
100 QtCore 0x1095987e0 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 208
101 QtGui 0x1088b3550 QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 2808
102 QtGui 0x108899428 QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 248
103 libqcocoa.dylib 0x107bb7ee8 0x107b80000 + 229096
104 CoreFoundation 0x1a1a3ca18 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 28
105 CoreFoundation 0x1a1a3c9ac __CFRunLoopDoSource0 + 176
106 CoreFoundation 0x1a1a3c71c __CFRunLoopDoSources0 + 244
107 CoreFoundation 0x1a1a3b320 __CFRunLoopRun + 836
108 CoreFoundation 0x1a1a3a888 CFRunLoopRunSpecific + 612
109 HIToolbox 0x1ab10ffa0 RunCurrentEventLoopInMode + 292
110 HIToolbox 0x1ab10fc30 ReceiveNextEventCommon + 236
111 HIToolbox 0x1ab10fb2c _BlockUntilNextEventMatchingListInModeWithFilter + 72
112 AppKit 0x1a4cbc424 _DPSNextEvent + 632
113 AppKit 0x1a4cbb5b4 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 728
114 AppKit 0x1a4caf9e4 -[NSApplication run] + 464
115 libqcocoa.dylib 0x107bb6c40 0x107b80000 + 224320
116 QtCore 0x1095947a8 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 524
117 QtCore 0x109598e10 QCoreApplication::exec() + 132
118 libqtscript_core.dylib 0x113d8822c qtscript_QCoreApplication_static_call(QScriptContext*, QScriptEngine*) + 1372
119 QtScript 0x105d1f6fc 0x105c2c000 + 997116
120 QtScript 0x105c90284 0x105c2c000 + 410244
121 QtScript 0x105c75ac0 0x105c2c000 + 301760
122 QtScript 0x105c6e554 0x105c2c000 + 271700
123 QtScript 0x105d07168 0x105c2c000 + 897384
124 QtScript 0x105d0b0d8 QScriptEngine::evaluate(QString const&, QString const&, int) + 332
125 libqcadecmaapi.dylib 0x1060546b4 RScriptHandlerEcma::eval(QString const&, QString const&) + 44
126 libqcadecmaapi.dylib 0x106053aa0 RScriptHandlerEcma::doScript(QString const&, QStringList const&) + 632
127 libqcadcore.dylib 0x10568bc38 RScriptHandler::init(QString const&, QStringList const&) + 1780
128 QCAD-Pro 0x104c35518 main + 4192
129 dyld 0x1a1633e50 start + 2544
Thread 1:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x1a1928a00 __select + 8
1 CoreFoundation 0x1a1a66344 __CFSocketManager + 636
2 libsystem_pthread.dylib 0x1a195d06c _pthread_start + 148
3 libsystem_pthread.dylib 0x1a1957e2c thread_start + 8
Thread 2:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x1a191dd70 mach_msg2_trap + 8
1 libsystem_kernel.dylib 0x1a192f8a4 mach_msg2_internal + 80
2 libsystem_kernel.dylib 0x1a19265c4 mach_msg_overwrite + 540
3 libsystem_kernel.dylib 0x1a191e0ec mach_msg + 24
4 CoreFoundation 0x1a1a3cbc0 __CFRunLoopServiceMachPort + 160
5 CoreFoundation 0x1a1a3b4ac __CFRunLoopRun + 1232
6 CoreFoundation 0x1a1a3a888 CFRunLoopRunSpecific + 612
7 AppKit 0x1a4de6410 _NSEventThread + 172
8 libsystem_pthread.dylib 0x1a195d06c _pthread_start + 148
9 libsystem_pthread.dylib 0x1a1957e2c thread_start + 8
Thread 3:: Qt bearer thread
0 libsystem_kernel.dylib 0x1a19262c0 poll + 8
1 QtCore 0x1095f5fa0 qt_safe_poll(pollfd*, unsigned int, timespec const*) + 436
2 QtCore 0x1095f77a0 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 980
3 QtCore 0x1095947a8 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 524
4 QtCore 0x1093e3884 QThread::exec() + 136
5 QtCore 0x1093e4848 0x1093c4000 + 133192
6 libsystem_pthread.dylib 0x1a195d06c _pthread_start + 148
7 libsystem_pthread.dylib 0x1a1957e2c thread_start + 8
Thread 4:
0 libsystem_pthread.dylib 0x1a1957e18 start_wqthread + 0
Thread 5:
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000002 x1: 0x000000016b1d0420 x2: 0x000000012e817838 x3: 0x000000016b1d02b8
x4: 0x0000000000000000 x5: 0x0000000000000074 x6: 0x0000000000000002 x7: 0x00000001113aca58
x8: 0x00000001149e61b8 x9: 0x000000000000000d x10: 0x000000012d9e61e0 x11: 0xffff000000000002
x12: 0x0000000000000010 x13: 0x0000000000000456 x14: 0x0000000000000456 x15: 0x000000012da57100
x16: 0x000000030e77809c x17: 0x00000001a17bce98 x18: 0x0000000000000000 x19: 0x0000000000000002
x20: 0x0000000000000002 x21: 0x000000000003e800 x22: 0x000000012e2a9a20 x23: 0x0000000000000002
x24: 0x0000000000000000 x25: 0x00000001131fda08 x26: 0x00000001131fda70 x27: 0x00000001149e6190
x28: 0xffff000000000002 fp: 0x000000016b1d0630 lr: 0x0000000105c759e8
sp: 0x000000016b1d0340 pc: 0x0000000105c75b74 cpsr: 0x20001000
far: 0x0000000000000000 esr: 0x92000006 (Data Abort) byte read Translation fault
Binary Images:
0x105c2c000 - 0x105d57fff org.qt-project.QtScript (5.15) <9c67824a-0c62-38b5-af36-d2273749b49d> /Applications/QCAD-Pro.app/Contents/Frameworks/QtScript.framework/Versions/5/QtScript
0x106014000 - 0x106f77fff libqcadecmaapi.dylib (*) <72f2ca88-3b5d-3d83-90a7-85588b2bf34e> /Applications/QCAD-Pro.app/Contents/Frameworks/libqcadecmaapi.dylib
0x105584000 - 0x10593ffff libqcadcore.dylib (*) <248220dc-4fbb-3410-8f10-3e8d42491469> /Applications/QCAD-Pro.app/Contents/Frameworks/libqcadcore.dylib
0x104d70000 - 0x104dbbfff libqcadgui.dylib (*) <fe4d3d65-69cc-371c-b2c9-d97a1f414aec> /Applications/QCAD-Pro.app/Contents/Frameworks/libqcadgui.dylib
0x107d78000 - 0x108183fff org.qt-project.QtWidgets (5.15) <4796d40a-2c12-3868-bdc4-f4dd2842e6f7> /Applications/QCAD-Pro.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
0x1093c4000 - 0x10989bfff org.qt-project.QtCore (5.15) <f240bdeb-d269-3366-a6da-5a7d6ce25197> /Applications/QCAD-Pro.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
0x108884000 - 0x108cebfff org.qt-project.QtGui (5.15) <065dfa63-76e8-3e06-b14c-f95cece5a413> /Applications/QCAD-Pro.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui
0x107b80000 - 0x107ccbfff libqcocoa.dylib (*) <2ae2783d-10bb-3477-8589-26977f29df63> /Applications/QCAD-Pro.app/Contents/PlugIns/platforms/libqcocoa.dylib
0x1a19bb000 - 0x1a1e92fff com.apple.CoreFoundation (6.9) <fd16d6d9-10c0-323b-b43b-9781c4a4d268> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x1a28e7000 - 0x1a331ffff com.apple.Foundation (6.9) <f1f5f857-8c3c-36d5-bc27-7702d6795468> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x1a4c83000 - 0x1a5b8dfff com.apple.AppKit (6.9) <dbbd4dea-6c68-3200-a81b-79b6a62f4669> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x1a95c3000 - 0x1a96cafff com.apple.ViewBridge (695.2.2) <23cf5ded-761a-39a9-9f79-b7f245c333fd> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x1ab0de000 - 0x1ab411fff com.apple.HIToolbox (2.1.1) <f1e0f4f6-dd7b-3d16-a622-5ee94a20fcaa> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x1193d4000 - 0x119b8bfff libqtscript_widgets.dylib (*) <25e4b16f-1af6-3ade-bbc3-734349772fe2> /Applications/QCAD-Pro.app/Contents/PlugIns/script/libqtscript_widgets.dylib
0x113d5c000 - 0x113f4ffff libqtscript_core.dylib (*) <e6042a9d-72f7-3cb5-a69a-57856272978f> /Applications/QCAD-Pro.app/Contents/PlugIns/script/libqtscript_core.dylib
0x104c28000 - 0x104c37fff org.qcad (3.27) <45c5128e-7ecc-378f-9f32-a364b3c18558> /Applications/QCAD-Pro.app/Contents/MacOS/QCAD-Pro
0x1a162e000 - 0x1a16b8b63 dyld (*) <487cfdeb-9b07-39bf-bfb9-970b61aea2d1> /usr/lib/dyld
0x1a191d000 - 0x1a1955ff3 libsystem_kernel.dylib (*) <aebf397e-e2ef-3a49-be58-23d4558511f6> /usr/lib/system/libsystem_kernel.dylib
0x1a1956000 - 0x1a1962ffb libsystem_pthread.dylib (*) <132084c6-c347-3489-9ac2-fcaad21cdb73> /usr/lib/system/libsystem_pthread.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.3G resident=0K(0%) swapped_out_or_unallocated=1.3G(100%)
Writable regions: Total=1.3G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.3G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 2
Activity Tracing 256K 1
CG backing stores 7104K 8
CG image 1232K 35
ColorSync 576K 29
CoreAnimation 640K 32
CoreGraphics 48K 3
CoreUI image data 4576K 33
Dispatch continuations 64.0M 1
Foundation 208K 3
JS VM Gigacage 20.8M 83
JS VM Isolated Heap 16.2M 4
Kernel Alloc Once 32K 1
MALLOC 1.0G 149
MALLOC guard page 192K 11
MALLOC_MEDIUM (reserved) 96.0M 1 reserved VM address space (unallocated)
STACK GUARD 56.1M 6
Stack 10.6M 6
VM_ALLOCATE 928K 40
WebKit Malloc 55.9M 68
__AUTH 1514K 293
__AUTH_CONST 18.5M 491
__CTF 756 1
__DATA 7883K 562
__DATA_CONST 30.2M 571
__DATA_DIRTY 1522K 178
__FONT_DATA 2352 1
__LINKEDIT 810.0M 77
__OBJC_CONST 3564K 253
__OBJC_RO 65.4M 1
__OBJC_RW 1986K 1
__TEXT 536.1M 585
dyld private memory 304K 3
mapped file 637.5M 104
shared memory 864K 14
TOTAL 3.4G 3651
TOTAL, minus reserved VM space 3.3G 3651
Full Report
{"app_name":"QCAD-Pro","timestamp":"2022-12-19 15:25:45.00 +0900","app_version":"3.27","slice_uuid":"45c5128e-7ecc-378f-9f32-a364b3c18558","build_version":"3.27.6","platform":1,"bundleID":"org.qcad","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 13.1 (22C65)","roots_installed":0,"name":"QCAD-Pro","incident_id":"1E7BF26A-D4B9-4A03-BF30-63A75C2C4C28"}
"uptime" : 91000,
"procRole" : "Foreground",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "MacBookAir10,1",
"coalitionID" : 17253,
"osVersion" : {
"train" : "macOS 13.1",
"build" : "22C65",
"releaseType" : "User"
"captureTime" : "2022-12-19 15:25:41.3255 +0900",
"incident" : "1E7BF26A-D4B9-4A03-BF30-63A75C2C4C28",
"pid" : 36505,
"translated" : false,
"cpuType" : "ARM-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2022-12-19 15:07:12.4854 +0900",
"procStartAbsTime" : 2166173207890,
"procExitAbsTime" : 2192778449614,
"procName" : "QCAD-Pro",
"procPath" : "\/Applications\/QCAD-Pro.app\/Contents\/MacOS\/QCAD-Pro",
"bundleInfo" : {"CFBundleShortVersionString":"3.27","CFBundleVersion":"3.27.6","CFBundleIdentifier":"org.qcad"},
"storeInfo" : {"deviceIdentifierForVendor":"E4642200-24C8-556D-8D1A-BC4DF23E2EF1","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "org.qcad",
"crashReporterKey" : "29701D90-97DB-1E76-C2C8-341CB6F1FE3F",
"throttleTimeout" : 2147483647,
"wakeTime" : 4890,
"sleepWakeUUID" : "ABAF0454-CC18-4C6A-802F-83D23029CD96",
"sip" : "enabled",
"vmRegionInfo" : "0 is not in any region. Bytes before following region: 4374822912\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 104c28000-104c38000 [ 64K] r-x\/r-x SM=COW ...acOS\/QCAD-Pro",
"exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000000"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":36505},
"vmregioninfo" : "0 is not in any region. Bytes before following region: 4374822912\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 104c28000-104c38000 [ 64K] r-x\/r-x SM=COW ...acOS\/QCAD-Pro",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":1171611,"threadState":{"x":[{"value":2},{"value":6092031008},{"value":5075204152},{"value":6092030648},{"value":0},{"value":116},{"value":2},{"value":4584032856},{"value":4640891320},{"value":13},{"value":5060321760},{"value":18446462598732840962},{"value":16},{"value":1110},{"value":1110},{"value":5060784384},{"value":13127614620},{"value":7004212888,"symbolLocation":0,"symbol":"szone_try_free_default"},{"value":0},{"value":2},{"value":2},{"value":256000},{"value":5069511200},{"value":2},{"value":0},{"value":4615821832},{"value":4615821936},{"value":4640891280},{"value":18446462598732840962}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4391918056},"cpsr":{"value":536875008},"fp":{"value":6092031536},"sp":{"value":6092030784},"esr":{"value":2449473542,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":4391918452,"matchesCrashFrame":1},"far":{"value":0}},"queue":"com.apple.main-thread","frames":[{"imageOffset":301940,"imageIndex":0},{"imageOffset":301544,"imageIndex":0},{"imageOffset":317600,"imageIndex":0},{"imageOffset":521808,"imageIndex":0},{"imageOffset":985908,"symbol":"QScriptValue::call(QScriptValue const&, QList<QScriptValue> const&)","symbolLocation":628,"imageIndex":0},{"imageOffset":11477244,"symbol":"REcmaShellViewFocusListenerAdapter::updateFocus(RGraphicsView*)","symbolLocation":576,"imageIndex":1},{"imageOffset":791076,"symbol":"RMainWindow::notifyViewFocusListeners(RGraphicsView*)","symbolLocation":356,"imageIndex":2},{"imageOffset":169248,"symbol":"RGraphicsViewQt::focusInEvent(QFocusEvent*)","symbolLocation":304,"imageIndex":3},{"imageOffset":289412,"symbol":"QWidget::event(QEvent*)","symbolLocation":988,"imageIndex":4},{"imageOffset":70832,"symbol":"QApplicationPrivate::notify_helper(QObject*, QEvent*)","symbolLocation":292,"imageIndex":4},{"imageOffset":75844,"symbol":"QApplication::notify(QObject*, QEvent*)","symbolLocation":556,"imageIndex":4},{"imageOffset":1918944,"symbol":"QCoreApplication::notifyInternal2(QObject*, QEvent*)","symbolLocation":208,"imageIndex":5},{"imageOffset":62268,"symbol":"QApplicationPrivate::setFocusWidget(QWidget*, Qt::FocusReason)","symbolLocation":380,"imageIndex":4},{"imageOffset":272336,"symbol":"QWidget::setFocus(Qt::FocusReason)","symbolLocation":604,"imageIndex":4},{"imageOffset":66924,"symbol":"QApplication::setActiveWindow(QWidget*)","symbolLocation":1012,"imageIndex":4},{"imageOffset":67952,"symbol":"QApplicationPrivate::notifyActiveWindowChange(QWindow*)","symbolLocation":52,"imageIndex":4},{"imageOffset":203580,"symbol":"QGuiApplicationPrivate::processActivatedEvent(QWindowSystemInterfacePrivate::ActivatedWindowEvent*)","symbolLocation":612,"imageIndex":6},{"imageOffset":91056,"symbol":"void QWindowSystemInterface::handleWindowActivated<QWindowSystemInterface::SynchronousDelivery>(QWindow*, Qt::FocusReason)","symbolLocation":168,"imageIndex":6},{"imageOffset":133724,"imageIndex":7},{"imageOffset":1961888,"symbol":"QMetaMethod::invoke(QObject*, Qt::ConnectionType, QGenericReturnArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument) const","symbolLocation":976,"imageIndex":5},{"imageOffset":147596,"imageIndex":7},{"imageOffset":484700,"symbol":"__CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__","symbolLocation":128,"imageIndex":8},{"imageOffset":1130580,"symbol":"___CFXRegistrationPost_block_invoke","symbolLocation":88,"imageIndex":8},{"imageOffset":1130396,"symbol":"_CFXRegistrationPost","symbolLocation":440,"imageIndex":8},{"imageOffset":293748,"symbol":"_CFXNotificationPost","symbolLocation":708,"imageIndex":8},{"imageOffset":38700,"symbol":"-[NSNotificationCenter postNotificationName:object:userInfo:]","symbolLocation":88,"imageIndex":9},{"imageOffset":1635516,"symbol":"-[NSWindow becomeKeyWindow]","symbolLocation":804,"imageIndex":10},{"imageOffset":1263384,"symbol":"-[NSWindow _changeKeyAndMainLimitedOK:]","symbolLocation":748,"imageIndex":10},{"imageOffset":8494764,"symbol":"-[NSWindow _orderOut:calculatingKeyWithOptions:documentWindow:]","symbolLocation":884,"imageIndex":10},{"imageOffset":509224,"symbol":"NSPerformVisuallyAtomicChange","symbolLocation":108,"imageIndex":10},{"imageOffset":8500572,"symbol":"-[NSWindow _reallyDoOrderWindowOutRelativeTo:]","symbolLocation":488,"imageIndex":10},{"imageOffset":8501416,"symbol":"-[NSWindow _reallyDoOrderWindow:]","symbolLocation":80,"imageIndex":10},{"imageOffset":10014540,"symbol":"-[NSSavePanel _reallyDoOrderWindow:]","symbolLocation":56,"imageIndex":10},{"imageOffset":8502008,"symbol":"-[NSWindow _doOrderWindow:]","symbolLocation":264,"imageIndex":10},{"imageOffset":10007448,"symbol":"-[NSSavePanel completeWithReturnCode:url:urls:]","symbolLocation":448,"imageIndex":10},{"imageOffset":10000820,"symbol":"-[NSSavePanel observeMostRecentCompletion:]","symbolLocation":464,"imageIndex":10},{"imageOffset":9999528,"symbol":"-[NSSavePanel observeValueForKeyPath:ofObject:change:context:]","symbolLocation":404,"imageIndex":10},{"imageOffset":209860,"symbol":"NSKeyValueNotifyObserver","symbolLocation":252,"imageIndex":9},{"imageOffset":930432,"symbol":"NSKeyValueDidChange","symbolLocation":360,"imageIndex":9},{"imageOffset":6081008,"symbol":"NSKeyValueDidChangeWithPerThreadPendingNotifications","symbolLocation":160,"imageIndex":9},{"imageOffset":108288,"symbol":"__47-[NSViewBridge setObject:forKey:withKVO:local:]_block_invoke","symbolLocation":300,"imageIndex":11},{"imageOffset":643584,"symbol":"withHintInProgress","symbolLocation":168,"imageIndex":11},{"imageOffset":107584,"symbol":"-[NSViewBridge setObject:forKey:withKVO:local:]","symbolLocation":532,"imageIndex":11},{"imageOffset":511604,"symbol":"-[NSRemoteViewMarshal setHostObject:forKey:]","symbolLocation":264,"imageIndex":11},{"imageOffset":409028,"symbol":"__invoking___","symbolLocation":148,"imageIndex":8},{"imageOffset":408636,"symbol":"-[NSInvocation invoke]","symbolLocation":428,"imageIndex":8},{"imageOffset":72628,"symbol":"__deferNSXPCInvocationOntoMainThread_block_invoke","symbolLocation":132,"imageIndex":11},{"imageOffset":27972,"symbol":"__wrapBlockWithVoucher_block_invoke","symbolLocation":56,"imageIndex":11},{"imageOffset":638828,"symbol":"kNotRunningOnAppKitCompatibleThread_block_invoke","symbolLocation":360,"imageIndex":11},{"imageOffset":529840,"symbol":"__CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__","symbolLocation":28,"imageIndex":8},{"imageOffset":529604,"symbol":"__CFRunLoopDoBlocks","symbolLocation":368,"imageIndex":8},{"imageOffset":526704,"symbol":"__CFRunLoopRun","symbolLocation":2452,"imageIndex":8},{"imageOffset":522376,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":8},{"imageOffset":204704,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":12},{"imageOffset":204260,"symbol":"ReceiveNextEventCommon","symbolLocation":672,"imageIndex":12},{"imageOffset":203564,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":72,"imageIndex":12},{"imageOffset":234532,"symbol":"_DPSNextEvent","symbolLocation":632,"imageIndex":10},{"imageOffset":230836,"symbol":"-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":728,"imageIndex":10},{"imageOffset":2567132,"symbol":"-[NSApplication _doModalLoop:peek:]","symbolLocation":216,"imageIndex":10},{"imageOffset":2562796,"symbol":"__35-[NSApplication runModalForWindow:]_block_invoke_2","symbolLocation":56,"imageIndex":10},{"imageOffset":2562712,"symbol":"__35-[NSApplication runModalForWindow:]_block_invoke","symbolLocation":108,"imageIndex":10},{"imageOffset":2560892,"symbol":"_NSTryRunModal","symbolLocation":100,"imageIndex":10},{"imageOffset":2560572,"symbol":"-[NSApplication runModalForWindow:]","symbolLocation":292,"imageIndex":10},{"imageOffset":9995552,"symbol":"-[NSSavePanel runModal]","symbolLocation":340,"imageIndex":10},{"imageOffset":444672,"imageIndex":7},{"imageOffset":459528,"imageIndex":7},{"imageOffset":2005768,"symbol":"QDialog::exec()","symbolLocation":264,"imageIndex":4},{"imageOffset":3459548,"symbol":"QtScriptShell_QFileDialog::exec()","symbolLocation":420,"imageIndex":13},{"imageOffset":2012116,"imageIndex":4},{"imageOffset":2012584,"symbol":"QDialog::qt_metacall(QMetaObject::Call, int, void**)","symbolLocation":172,"imageIndex":4},{"imageOffset":2117520,"symbol":"QFileDialog::qt_metacall(QMetaObject::Call, int, void**)","symbolLocation":32,"imageIndex":4},{"imageOffset":1077480,"imageIndex":0},{"imageOffset":1071824,"imageIndex":0},{"imageOffset":1014608,"imageIndex":0},{"imageOffset":1012888,"imageIndex":0},{"imageOffset":410244,"imageIndex":0},{"imageOffset":301760,"imageIndex":0},{"imageOffset":271700,"imageIndex":0},{"imageOffset":897384,"imageIndex":0},{"imageOffset":913624,"symbol":"QScriptEngine::evaluate(QString const&, QString const&, int)","symbolLocation":332,"imageIndex":0},{"imageOffset":263860,"symbol":"RScriptHandlerEcma::eval(QString const&, QString const&)","symbolLocation":44,"imageIndex":1},{"imageOffset":269844,"symbol":"RScriptHandlerEcma::createActionApplicationLevel(QString const&, RGuiAction*)","symbolLocation":644,"imageIndex":1},{"imageOffset":1081404,"symbol":"RScriptHandler::triggerActionApplicationLevel(QString const&, RGuiAction*)","symbolLocation":88,"imageIndex":2},{"imageOffset":611416,"symbol":"RGuiAction::slotTrigger(QString const&)","symbolLocation":444,"imageIndex":2},{"imageOffset":1744176,"symbol":"RGuiAction::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)","symbolLocation":168,"imageIndex":2},{"imageOffset":2116472,"imageIndex":5},{"imageOffset":33608,"symbol":"QAction::activate(QAction::ActionEvent)","symbolLocation":308,"imageIndex":4},{"imageOffset":923284,"imageIndex":4},{"imageOffset":927452,"symbol":"QAbstractButton::mouseReleaseEvent(QMouseEvent*)","symbolLocation":256,"imageIndex":4},{"imageOffset":1899228,"symbol":"QToolButton::mouseReleaseEvent(QMouseEvent*)","symbolLocation":20,"imageIndex":4},{"imageOffset":288552,"symbol":"QWidget::event(QEvent*)","symbolLocation":128,"imageIndex":4},{"imageOffset":1901048,"symbol":"QToolButton::event(QEvent*)","symbolLocation":280,"imageIndex":4},{"imageOffset":70832,"symbol":"QApplicationPrivate::notify_helper(QObject*, QEvent*)","symbolLocation":292,"imageIndex":4},{"imageOffset":81388,"symbol":"QApplication::notify(QObject*, QEvent*)","symbolLocation":6100,"imageIndex":4},{"imageOffset":1918944,"symbol":"QCoreApplication::notifyInternal2(QObject*, QEvent*)","symbolLocation":208,"imageIndex":5},{"imageOffset":73256,"symbol":"QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool)","symbolLocation":988,"imageIndex":4},{"imageOffset":409656,"imageIndex":4},{"imageOffset":405592,"imageIndex":4},{"imageOffset":70832,"symbol":"QApplicationPrivate::notify_helper(QObject*, QEvent*)","symbolLocation":292,"imageIndex":4},{"imageOffset":75844,"symbol":"QApplication::notify(QObject*, QEvent*)","symbolLocation":556,"imageIndex":4},{"imageOffset":1918944,"symbol":"QCoreApplication::notifyInternal2(QObject*, QEvent*)","symbolLocation":208,"imageIndex":5},{"imageOffset":193872,"symbol":"QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*)","symbolLocation":2808,"imageIndex":6},{"imageOffset":87080,"symbol":"QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":248,"imageIndex":6},{"imageOffset":229096,"imageIndex":7},{"imageOffset":530968,"symbol":"__CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__","symbolLocation":28,"imageIndex":8},{"imageOffset":530860,"symbol":"__CFRunLoopDoSource0","symbolLocation":176,"imageIndex":8},{"imageOffset":530204,"symbol":"__CFRunLoopDoSources0","symbolLocation":244,"imageIndex":8},{"imageOffset":525088,"symbol":"__CFRunLoopRun","symbolLocation":836,"imageIndex":8},{"imageOffset":522376,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":8},{"imageOffset":204704,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":12},{"imageOffset":203824,"symbol":"ReceiveNextEventCommon","symbolLocation":236,"imageIndex":12},{"imageOffset":203564,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":72,"imageIndex":12},{"imageOffset":234532,"symbol":"_DPSNextEvent","symbolLocation":632,"imageIndex":10},{"imageOffset":230836,"symbol":"-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":728,"imageIndex":10},{"imageOffset":182756,"symbol":"-[NSApplication run]","symbolLocation":464,"imageIndex":10},{"imageOffset":224320,"imageIndex":7},{"imageOffset":1902504,"symbol":"QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":524,"imageIndex":5},{"imageOffset":1920528,"symbol":"QCoreApplication::exec()","symbolLocation":132,"imageIndex":5},{"imageOffset":180780,"symbol":"qtscript_QCoreApplication_static_call(QScriptContext*, QScriptEngine*)","symbolLocation":1372,"imageIndex":14},{"imageOffset":997116,"imageIndex":0},{"imageOffset":410244,"imageIndex":0},{"imageOffset":301760,"imageIndex":0},{"imageOffset":271700,"imageIndex":0},{"imageOffset":897384,"imageIndex":0},{"imageOffset":913624,"symbol":"QScriptEngine::evaluate(QString const&, QString const&, int)","symbolLocation":332,"imageIndex":0},{"imageOffset":263860,"symbol":"RScriptHandlerEcma::eval(QString const&, QString const&)","symbolLocation":44,"imageIndex":1},{"imageOffset":260768,"symbol":"RScriptHandlerEcma::doScript(QString const&, QStringList const&)","symbolLocation":632,"imageIndex":1},{"imageOffset":1080376,"symbol":"RScriptHandler::init(QString const&, QStringList const&)","symbolLocation":1780,"imageIndex":2},{"imageOffset":54552,"symbol":"main","symbolLocation":4192,"imageIndex":15},{"imageOffset":24144,"symbol":"start","symbolLocation":2544,"imageIndex":16}]},{"id":1171642,"name":"com.apple.CFSocket.private","frames":[{"imageOffset":47616,"symbol":"__select","symbolLocation":8,"imageIndex":17},{"imageOffset":701252,"symbol":"__CFSocketManager","symbolLocation":636,"imageIndex":8},{"imageOffset":28780,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":18},{"imageOffset":7724,"symbol":"thread_start","symbolLocation":8,"imageIndex":18}]},{"id":1171652,"name":"com.apple.NSEventThread","frames":[{"imageOffset":3440,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":17},{"imageOffset":75940,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":17},{"imageOffset":38340,"symbol":"mach_msg_overwrite","symbolLocation":540,"imageIndex":17},{"imageOffset":4332,"symbol":"mach_msg","symbolLocation":24,"imageIndex":17},{"imageOffset":531392,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":8},{"imageOffset":525484,"symbol":"__CFRunLoopRun","symbolLocation":1232,"imageIndex":8},{"imageOffset":522376,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":8},{"imageOffset":1455120,"symbol":"_NSEventThread","symbolLocation":172,"imageIndex":10},{"imageOffset":28780,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":18},{"imageOffset":7724,"symbol":"thread_start","symbolLocation":8,"imageIndex":18}]},{"id":1171674,"name":"Qt bearer thread","frames":[{"imageOffset":37568,"symbol":"poll","symbolLocation":8,"imageIndex":17},{"imageOffset":2301856,"symbol":"qt_safe_poll(pollfd*, unsigned int, timespec const*)","symbolLocation":436,"imageIndex":5},{"imageOffset":2308000,"symbol":"QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":980,"imageIndex":5},{"imageOffset":1902504,"symbol":"QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":524,"imageIndex":5},{"imageOffset":129156,"symbol":"QThread::exec()","symbolLocation":136,"imageIndex":5},{"imageOffset":133192,"imageIndex":5},{"imageOffset":28780,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":18},{"imageOffset":7724,"symbol":"thread_start","symbolLocation":8,"imageIndex":18}]},{"id":1183764,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":18}]},{"id":1183807,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":18}]}],
"usedImages" : [
had to cut some part from here...
User ID: 501
Report Version: 12
Thread 4:
Thread 5:
Binary Images:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
VIRTUAL REGION
CG image 1232K 35
ColorSync 576K 29
CoreGraphics 48K 3
Foundation 208K 3
MALLOC 1.0G 149
STACK GUARD 56.1M 6
Stack 10.6M 6
VM_ALLOCATE 928K 40
__AUTH 1514K 293
__CTF 756 1
__DATA 7883K 562
__FONT_DATA 2352 1
__OBJC_RO 65.4M 1
__OBJC_RW 1986K 1
__TEXT 536.1M 585
TOTAL 3.4G 3651
Full Report
"uptime" : 91000,
"version" : 2,
"userID" : 501,
"osVersion" : {
"build" : "22C65",
"pid" : 36505,
"bug_type" : "309",
"parentPid" : 1,
"wakeTime" : 4890,
"sip" : "enabled",
"usedImages" : [
Gerome Meyer
ジェローム メイヤー<
ジェローム メイヤー<
