QCAD not opening after install on Ubuntu 20
crashlandon
Post by crashlandon » Sun Nov 22, 2020 2:47 pm
After installing qcad-3.25.2-trial-linux-x86_64.run on Ubuntu 20.04.1, and running QCAD, the GUI is not coming up. The processor grinds away for maybe 30 seconds, then drops to idle, and the GUI does not come up. Seems to be QT related, but couldn't find a previous post that seemed to reflect this case.
Here's the start of the output:
QCAD version  3.25.2
Warning:  RPropertyTypeId::generateId: property already initialized:  7RObject : "" : "Invisible"
07:12:30: Debug:    Renaming old unversioned config file from '/home/landon/.config/QCAD/QCAD3.conf' to '/home/landon/.config/QCAD/QCAD3_old.conf'
Warning:  QWidget::setMinimumSize: (FirstStart/QDialog) Negative sizes (-492131406,-492131150) are not possible
Warning:  QXcbConnection: XCB error: 2 (BadValue), sequence: 213, resource id: 0, major code: 1 (CreateWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 214, resource id: 56623108, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 215, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 216, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 217, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 219, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 220, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 221, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 225, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 226, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 229, resource id: 56623108, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 230, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 233, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 234, resource id: 56623108, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 235, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 238, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 239, resource id: 56623108, major code: 19 (DeleteProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 240, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 242, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 243, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 245, resource id: 56623108, major code: 19 (DeleteProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 246, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 247, resource id: 56623108, major code: 12 (ConfigureWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 248, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 249, resource id: 56623108, major code: 12 (ConfigureWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 265, resource id: 56623108, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 266, resource id: 56623108, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 267, resource id: 56623108, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 268, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 269, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 270, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 271, resource id: 56623108, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 272, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 273, resource id: 56623108, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 274, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 275, resource id: 56623108, major code: 8 (MapWindow), minor code: 0
petevick
Re: QCAD not opening after install on Ubuntu 20
Post by petevick » Sun Nov 22, 2020 3:31 pm
You could try the QT 5.14 install, it's what I run in Mint 20
Pete Vickerstaff
