Cannot start QCad
daxq
Cannot start QCad
Post by daxq » Tue Feb 07, 2023 8:57 pm
Tried Googling, but having no luck figuring this out. I have installed QCad on a BeeLink Debian Linux computer:
daxq@beelink:~$ neofetch
       _,met$$$$$gg.          daxq@beelink
    ,g$$$$$$$$$$$$$$$P.       ------------
  ,g$$P"     """Y$$.".        OS: Debian GNU/Linux 11 (bullseye) x86_64
 ,$$P'              `$$$.     Host: MINI S
',$$P       ,ggs.     `$$b:   Kernel: 6.0.0-0.deb11.6-amd64
`d$$'     ,$P"'   .    $$$    Uptime: 2 days, 57 mins
 $$P      d$'     ,    $$P    Packages: 1068 (dpkg)
 $$:      $$.   -    ,d$$'    Shell: bash 5.1.4
 $$;      Y$b._   _,d$P'      Resolution: 1360x768
 Y$$.    `.`"Y$$$$P"'         DE: Xfce 4.16
 `$$b      "-.__              WM: Xfwm4
  `Y$$                        WM Theme: Default
   `Y$$.                      Theme: Xfce [GTK2], Adwaita [GTK3]
     `$$b.                    Icons: Tango [GTK2], Adwaita [GTK3]
       `Y$$b.                 Terminal: xfce4-terminal
          `"Y$b._             Terminal Font: Monospace 12
              `"""            CPU: Intel Celeron N5095A (4) @ 2.900GHz
                              GPU: Intel JasperLake [UHD Graphics]
                              Memory: 1946MiB / 7733MiB
QCad version is 3.27.8
I am sure the program was initially running fine then just stopped. Not sure what I did (or accidentally removed from my system) to cause it to stop displaying the program (it just silently runs in the background without displaying any graphical interface) - I see the errors its generating, but do not understand how to resolve it (I have tried deleting the entire /opt installation and reinstalling to no avail):
daxq@beelink:~/opt/qcad-3.27.8-trial-linux-x86_64$ ./qcad %f
QCAD version  3.27.8
13:34:51: Debug:    loading plugins...
13:34:51: Debug:    loading static plugins...
Warning:  QXcbConnection: XCB error: 2 (BadValue), sequence: 228, resource id: 0, major code: 1 (CreateWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 229, resource id: 41943045, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 230, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 231, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 232, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 234, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 235, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 236, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 240, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 241, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 244, resource id: 41943045, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 245, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 248, resource id: 41943045, major code: 19 (DeleteProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 249, resource id: 41943045, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 250, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 253, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 254, resource id: 41943045, major code: 19 (DeleteProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 255, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 257, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 258, resource id: 41943045, major code: 19 (DeleteProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 259, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 260, resource id: 41943045, major code: 12 (ConfigureWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 276, resource id: 41943045, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 277, resource id: 41943045, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 278, resource id: 41943045, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 279, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 280, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 281, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 282, resource id: 41943045, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 283, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 284, resource id: 41943045, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 285, resource id: 41943045, major code: 19 (DeleteProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 286, resource id: 41943045, major code: 8 (MapWindow), minor code: 0
13:34:52: Debug:    CadToolBar.initStyle
13:34:52: Debug:    EcmaScriptShell.initStyle:
13:34:52: Debug:    loading plugins...
13:34:52: Debug:    loading static plugins...
Warning:  QWidget::setMinimumSize: (BlockListDock/RDockWidget) Negative sizes (2,-1) are not possible
Warning:  QWidget::setMaximumSize: (BlockListDock/RDockWidget) Negative sizes (524287,-1) are not possible
Warning:  QWidget::setMinimumSize: (PropertyEditorDock/RDockWidget) Negative sizes (4,-1) are not possible
Warning:  QWidget::setMaximumSize: (PropertyEditorDock/RDockWidget) Negative sizes (524287,-1) are not possible
Warning:  QWidget::setMinimumSize: (LayerListProDock/RDockWidget) Negative sizes (2,-1) are not possible
Warning:  QWidget::setMaximumSize: (LayerListProDock/RDockWidget) Negative sizes (524287,-1) are not possible
Warning:  QWidget::setMinimumSize: (Options/QToolBar) Negative sizes (0,-1677721600) are not possible
Warning:  QWidget::setMaximumSize: (Options/QToolBar) Negative sizes (16777215,-1677721600) are not possible
13:34:55: Debug:    loading plugins...
13:34:55: Debug:    loading static plugins...
Warning:  QWidget::setMinimumSize: (TrExpStart/QDialog) Negative sizes (-492131520,-475354325) are not possible
Warning:  QXcbConnection: XCB error: 2 (BadValue), sequence: 291, resource id: 0, major code: 1 (CreateWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 292, resource id: 41943053, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 293, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 294, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 295, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 297, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 298, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 299, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 300, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 301, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 304, resource id: 41943053, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 305, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 308, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 309, resource id: 41943053, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 310, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 313, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 314, resource id: 41943053, major code: 19 (DeleteProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 315, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 317, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 318, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 319, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 2 (BadValue), sequence: 322, resource id: 0, major code: 1 (CreateWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 323, resource id: 41943056, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 324, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 325, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 326, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 328, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 329, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 330, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 331, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 332, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 335, resource id: 41943056, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 336, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 339, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 340, resource id: 41943056, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 341, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 344, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 345, resource id: 41943056, major code: 19 (DeleteProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 346, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 348, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 349, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 351, resource id: 41943056, major code: 19 (DeleteProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 352, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 353, resource id: 41943056, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 354, resource id: 41943056, major code: 12 (ConfigureWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 357, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 358, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 359, resource id: 41943053, major code: 12 (ConfigureWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 360, resource id: 41943053, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 361, resource id: 41943053, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 362, resource id: 41943053, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 363, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 364, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 365, resource id: 41943053, major code: 19 (DeleteProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 366, resource id: 41943053, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 367, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 368, resource id: 41943053, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 369, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 370, resource id: 41943053, major code: 1 (CreateWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 371, resource id: 41943053, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 372, resource id: 41943053, major code: 19 (DeleteProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 373, resource id: 41943058, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 374, resource id: 41943053, major code: 8 (MapWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 376, resource id: 41943045, major code: 10 (UnmapWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 379, resource id: 41943045, major code: 4 (DestroyWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 2 (BadValue), sequence: 381, resource id: 0, major code: 1 (CreateWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 382, resource id: 41943060, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 383, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 384, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 385, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 387, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 388, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 389, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 390, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 391, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 394, resource id: 41943060, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 395, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 398, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 399, resource id: 41943060, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 400, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 403, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 404, resource id: 41943060, major code: 19 (DeleteProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 405, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 407, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 408, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 410, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 411, resource id: 41943060, major code: 12 (ConfigureWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 412, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 413, resource id: 41943060, major code: 12 (ConfigureWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 414, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 415, resource id: 41943060, major code: 12 (ConfigureWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 416, resource id: 41943060, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 417, resource id: 41943060, major code: 2 (ChangeWindowAttributes), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 418, resource id: 41943060, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 419, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 420, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 421, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 422, resource id: 41943060, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 423, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 424, resource id: 41943060, major code: 20 (GetProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 425, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 426, resource id: 41943060, major code: 1 (CreateWindow), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 427, resource id: 41943060, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 428, resource id: 41943060, major code: 19 (DeleteProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 429, resource id: 41943062, major code: 18 (ChangeProperty), minor code: 0
Warning:  QXcbConnection: XCB error: 3 (BadWindow), sequence: 430, resource id: 41943060, major code: 8 (MapWindow), minor code: 0
Warning:  QWidget::setMinimumSize: (TrExpStart/QDialog) Negative sizes (-492131520,-492131540) are not possible
^C
I am guessing something package I may have uninstalled might have grabbed a required package from QCad, but just do not know.
Any suggestions or assistance greatly appreciated.
Re: Cannot start QCad
Post by CVH » Thu Feb 09, 2023 9:35 am
Have a try with the latest release.
Ensure you have the correct installation file or package for your system.
Perhaps first removing anything related with QCAD is a good idea.
Including removing/renaming the QCAD.ini/config file.
daxq
Post by daxq » Thu Feb 09, 2023 3:22 pm
I do see that a new version just came out, and will try that as well - but I did completely remove the QCad install folder /home/opt/qcad... and try reinstalling it to no avail. Unless the QCad.ini is not kept in that folder, pretty sure I got it too. Thanks for the response, will see if .9 makes a difference.
Post by CVH » Thu Feb 09, 2023 5:54 pm
Normally it is not situated in the installation folder:
daxq
Post by daxq » Thu Feb 09, 2023 6:05 pm
Well I found out I was having issues with my hard drive on that computer and had to install a new drive and reinstall the OS anyway - so its got a definitely clean install now! and is running again - thanks for your information and assistance. You were also correct on the config file - I had not cleared that when I did my reinstall of the software - so thanks for that as well.
daxq
Post by daxq » Fri Feb 10, 2023 3:07 pm
Well I spoke too soon - I had to rebuild this desktop (cause of issues with the M.2 ssd) so I brought it into work and rebuilt things just as before with a new M.2 - and everything was working great at work. Now that the computer is up and running at home, I am getting the same issue - clicking the Qcad icon gets the program running in the background, but there is no GUI interface. The only thing different from work (aside from the LAN) where I built this, is the monitor - at work I was using a ViewSonic display - at home I'm using an older LG TV @ 1360x768 ~16:9 - is it possible that its the odd resolution and display is causing the graphics to fail to launch? When I get home i'll try to find a different display to use - but I never would've guessed that to cause the program to fail to run?
Post by CVH » Sat Feb 11, 2023 4:58 am
Most probably it is not the used monitor.
I find similar warnings as yours here:
https://www.qcad.org/rsforum/viewtopic. ... ion#p35924
https://www.qcad.org/rsforum/viewtopic. ... ion#p30446
It seems that in both cases using the Qt 5.14 package solved the issue. :wink:
daxq
Post by daxq » Sat Feb 11, 2023 4:57 pm
Well this has got me pretty perplexed and im probly just too noob in linux - but I do not find a QT install on either of my desktops:
Work desktop: BeeLink SER5 - Debian Bullseye - XFCE4 - QCad working fine
Home desktop: BeeLink MiniS - Debian Bullseye - XFCE4 - QCad no worky
Unless the QT libraries are included in the /opt folder that QCad put in my /home/daxq/opt folder? And then I don't understand why it is working on the SER5 unless it has more to do with the hardware:
Work
      _,met$$$$$gg.          daxq@Ser5-E
 ,$$P'              `$$$.     Host: SER
',$$P       ,ggs.     `$$b:   Kernel: 5.10.0-21-amd64
`d$$'     ,$P"'   .    $$$    Uptime: 1 day, 21 hours, 27 mins
 $$P      d$'     ,    $$P    Packages: 1291 (dpkg)
 $$;      Y$b._   _,d$P'      Resolution: 1920x1080
              `"""            CPU: AMD Ryzen 5 5560U with Radeon Graphics (12)
                              GPU: AMD ATI 03:00.0 Cezanne
                              Memory: 3275MiB / 12968MiB
Home:
       _,met$$$$$gg.          daxq@BeeLinkMini
    ,g$$$$$$$$$$$$$$$P.       ----------------
`d$$'     ,$P"'   .    $$$    Uptime: 1 day, 44 mins
 $$P      d$'     ,    $$P    Packages: 958 (dpkg)
                              GPU: Intel Device 4e55
                              Memory: 3406MiB / 7733MiB
either way, it really seems odd that QCad ran fine when I was at work on the MiniS using the Viewsonic - after its initial install. Why would it break when I got it home? I think I can get QT5.15 to install on the home MiniS Debian system, but do not know how to tell QCad to use it?
daxq@BeeLinkMini:~$ qmake --version
QMake version 3.1
Using Qt version 5.15.2 in /usr/lib/x86_64-linux-gnu
Or does it have to be 5.14 only to work?
Post by CVH » Sat Feb 11, 2023 8:17 pm
I see that you used the qcad-3.27.8-trial-linux-x86_64 package.
That is the one under the QCAD logo on the download page .. QCAD Professional Trial .. Linux .. 64bit Installer.
https://www.ribbonsoft.com/en/download
Now scroll down on that page to see more options.
That's what I meant by:
The version doesn't really matter for now.
Only, every update may include novelties and/or some bug fixes.
This is how far I can help you ... I am a Win user.
daxq
Post by daxq » Sat Feb 11, 2023 10:17 pm
I think i just misread your post - and was unaware of more download types available lower. I am now trying the install package with the 5.14 on it and will see what that brings. Seems to be running now, ill see if it sticks! Thanks.
