vport is "on" but still do not show contents
ubi_laptop
Post by ubi_laptop » Tue Feb 07, 2023 3:18 pm
Hi, I did open a file with viewports, they are still on, but do not how anything.
Since I did exchange this same file with an Autocad user, I had the idea to check the "view center".
It seem that during the conversion something was messed up (see screeshot).
the two files show to differnet valus, although I'm sure nobody changed them, but it was something happende during the conversion.
Anny hint how to fix that problem : the program changes orign point of "view center" in viewport by simply importing. ..
D
Re: vport is "on" but still do not show contents
Post by andrew » Tue Feb 07, 2023 3:29 pm
Please always indicate your operating system and QCAD version. Please attach the drawing file(s). See also forum rules above, thanks.
