'Insert Block' in menu 'Block' grayed out.
DrM73
Post by DrM73 » Tue Nov 29, 2022 6:38 pm
When I want to insert a block in QCAD Professional Trial version 3.27.8.0 (3.27.8) via menu 'Block' I see that the 'Insert Block' menu item has been grayed out. See attached screenshot. Even executing the command blockinsert doesn't function at all. I run this program under Linux Mint 20.3 Xfce 64 bit edition.
How can I enable 'Insert Block' in the menu 'Block' and insert a block from a file into any drawing? Blocks are very important in CAD drawings, especially when drawing circuit diagrams, etc.
Re: 'Insert Block' in menu 'Block' grayed out.
Post by andrew » Tue Nov 29, 2022 6:58 pm
This menu is to insert an existing block from the drawings block list into the drawing (see View > Block List).
To insert a block from a DXF or DWG file, you can use:
File > Import
or
Drag and drop the file from a file manager into your drawing area
or
use the QCAD Part Library Browser.
DrM73
Post by DrM73 » Tue Nov 29, 2022 7:07 pm
File > Import, how do I preview a block or drawing in the 'Import Drawing' window? When inserting symbols from a library, it is very useful to see it in the 'Import Drawing' window when browsing for symbols in a large symbol library with many symbols.
Post by CVH » Tue Nov 29, 2022 7:20 pm
With Open or Import Drawing there is no preview.
Your dialog shows the path of the library items.
When you use the Library Browser then there are previews of the items.
To display the Library Browser see the View menu or simply type the 'G' and the 'L' key.
Post by CVH » Wed Nov 30, 2022 7:39 am
Just mentioning that there is a feature request: https://qcad.org/bugtracker/index.php?d ... sk_id=2351
Also broken because of Qt: https://qcad.org/bugtracker/index.php?d ... ask_id=586
