[solved] Cannot correctly export/print to pdf with page larger than A4
Ryan Hao
Post by Ryan Hao » Wed Nov 16, 2022 6:22 am
Version:
QCAD Professional 3.27.7.0
Windows 10
Details:
system_info.txt
System Info copied from 'Help-About-System'
(14.77 KiB) Downloaded 158 times
What's the Problem:
The 'Export to PDF' and 'Print' action produce incorrect page content when the page layout size is above A4.
How to Reproduce:
100%. Just print anything in a layout larger than A4.
'Ctrl + N' to create a new drawing, draw a rectangle, and print/export it in different scale and layout page sizes.
Here are the dxf and all produced pdf for you:
reproduce.zip
Test dxf file and all exported/printed test pdf
(17.21 KiB) Downloaded 153 times
What Happend Before the Problem:
Upgrade to QCAD 3.27.7.0 (from a version installed 1 year before)
Re: Cannot correctly export/print to pdf with page larger than A4
Post by CVH » Wed Nov 16, 2022 7:04 am
I can not replicate this on Win7 32 bit with QCAD PRO versions 3.27.6 and .8 in any way.
Not as plain pdf export of Model_Space nor with the use of Viewports and Layouts.
All turns out in a pdf file with the correct paper size.
I was only annoyed that the pdf export doesn't remember my last used file path. :roll:
Post by Husky » Wed Nov 16, 2022 7:05 am
Hi Ryan Hao,
this was a bug uncovered in QCAD Professional Version 3.27.7.0 and fixed for the already released version QCAD Professional 3.27.8.0.
https://www.qcad.org/en/changelog
Please update to the current version. Thanks.
Ryan Hao
Post by Ryan Hao » Wed Nov 16, 2022 7:26 am
Hi Ryan Hao,
My access to professional updates just outdated before this fix was released. Is there any way I can get this fixed? This bug makes me painful.
