Drawing preferences not saved
n_spect_r
Post by n_spect_r » Sun Feb 06, 2022 12:46 pm
I make parts for several customers, we need to have drawings with dimension decimals to 4 places, and angles to 3. I frequently get drawings sent to me with 2 places and 1. I can go to Edit, Drawing preferences and change it. But even after saving the file, the next time I open it the dimensions are back to the original settings. Running Windows 7 and QcadCam 3.25.2
Re: Drawing preferences not saved
Post by Husky » Sun Feb 06, 2022 5:47 pm
Can't reproduce the issue. Please attache an example drawing. Thanks.
Do you open or import the drawing?
