QCAD version: 3.26.4 ( qcad-3.26.4-pro-linux-qt5.14-x86_64.run )
Command
dwgmapconvert -retain-texts -segment-length=0.1 -crs-in=EPSG:5186 -crs-out=EPSG:3857 -platform offscreen -o /something/converted_5186_sample.dxf /something/sample.dxf
QCAD version 3.26.4
Warning: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
05:15:37: Debug: Input file: /something/sample.dxf
05:15:37: Debug: Output file: /something/converted_5186_sample.dxf
05:15:37: Debug: calling odInitialize
Warning: RDwgImporter::importFile: 3: OdError:
05:15:40: Debug: "RDwgServices::printErrorStackTrace: Invalid input"
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(1224407.051594, -101195.333185, 0.000000, 1)") does not connect to start ("RVector(1224407.925877, -101180.999567, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(1482832.967754, 234242.005367, 0.000000, 1)") does not connect to start ("RVector(1482832.974207, 234242.004906, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(445700.000005, 2532750.000031, 0.000000, 1)") does not connect to start ("RVector(446100.000006, 2532750.000030, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(1453700.000489, 1463550.000363, 0.000000, 1)") does not connect to start ("RVector(1454100.000491, 1463550.000362, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(445700.000005, 2176350.000031, 0.000000, 1)") does not connect to start ("RVector(446100.000006, 2176350.000030, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(445700.000005, 1463550.000031, 0.000000, 1)") does not connect to start ("RVector(446100.000006, 1463550.000030, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(949700.000489, 1463550.000031, 0.000000, 1)") does not connect to start ("RVector(950100.000491, 1463550.000030, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(445700.000005, 394350.000031, 0.000000, 1)") does not connect to start ("RVector(446100.000006, 394350.000030, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(445700.000005, 750750.000031, 0.000000, 1)") does not connect to start ("RVector(446100.000006, 750750.000030, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(430200.000000, 2526600.000000, 0.000000, 1)") does not connect to start ("RVector(429700.000000, 2537400.000000, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(-794848.349461, 750750.000031, 0.000000, 1)") does not connect to start ("RVector(-794448.349460, 750750.000030, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(-794848.349461, 1463550.000031, 0.000000, 1)") does not connect to start ("RVector(-794448.349460, 1463550.000030, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(-810348.349465, 2526600.000000, 0.000000, 1)") does not connect to start ("RVector(-810848.349466, 2537400.000000, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(-794848.349461, 394350.000031, 0.000000, 1)") does not connect to start ("RVector(-794448.349460, 394350.000030, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(-794848.349461, 2176350.000031, 0.000000, 1)") does not connect to start ("RVector(-794448.349460, 2176350.000030, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(-794848.349461, 2532750.000031, 0.000000, 1)") does not connect to start ("RVector(-794448.349460, 2532750.000030, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(-290848.348976, 1463550.000031, 0.000000, 1)") does not connect to start ("RVector(-290448.348975, 1463550.000030, 0.000000, 1)")
Warning: RHatchData::getBoundaryPath: loop not closed: end ( "RVector(213151.651024, 1463550.000363, 0.000000, 1)") does not connect to start ("RVector(213551.651025, 1463550.000362, 0.000000, 1)")
Warning: "Import for file /something/sample.dxf failed"
Cannot import file: /something/sample.dxf
It's a confidential file, so I think I can only forward it by e-mail.
Question
I made sure that the file was in that location.
Only certain files seem to have errors.
How can I solve this problem?
Even if there is an error, the exit code seems to be falling to zero.
