[Solved]Error viewing file
debbio
Post by debbio » Mon Aug 02, 2021 1:33 pm
Hi all! I'm new, I've bought the professional version of qcad to open the file you see in attachments, but I cannot view all the measures and the lines appear strange.
Can you please check what's happening?
In the png file you can see a part of the dwg opened with Autocad Trueview with correct lines and measure view
EDIT: I'm on windows 10 64bit, last qcad stable version
Immagine 2021-08-02 143247.png (22.62 KiB) Viewed 6513 times
piante prime piazze la febbre.dwg
(106.41 KiB) Downloaded 344 times
Giuliano69
Re: Error viewing file
Post by Giuliano69 » Mon Aug 02, 2021 2:07 pm
Hi
The problem si that the font is too small compared to how big is the drawing...
Considering how large is your drawing, I would try this GENERAL setting:
Modifica - >preferenze disegno - > Quota -> Impostazioni quota - > Fattore di Scala = 500
IF your want to act on a single quote, just select properties, and change "Scala"
BR
PS
@ Andrew Mustun
Just an idea ....
How is Autocad choosing (right) how big the font should be as default ?
Maybe could exist some empirical relation between how big is the drawing and how big needs to be the font ...
debbio
Post by debbio » Mon Aug 02, 2021 2:17 pm
Hi Giuliano, thank you for your answer, but it's not only a problem of dimension quota.. You can see I've red lines all over the drawing (instead they are more precise on autocad viewer)
EDIT: The lines that have a specific angle have the extension of the measure lines too long.
Immagine 2021-08-02 151555.png (10.97 KiB) Viewed 6505 times
Post by Husky » Mon Aug 02, 2021 7:24 pm
Please attache the dwg to your post. Thanks.
debbio
Post by debbio » Mon Aug 02, 2021 8:11 pm
in the first post you can see the dwg file
Post by Husky » Mon Aug 02, 2021 9:11 pm
Sorry - I missed that ... :oops:
The dwg is not a plain 2D drawing. It has also 3D features especially at the dims. QCAD is a 2D only CAD program and can't handle 3D features.
The Autocad Trueview viewer is able to read 2D AND 3D.
debbio
Post by debbio » Mon Aug 02, 2021 11:07 pm
But if I recreate the measure inside qcad, the view is the same... The lines are too far from the measured lines
Post by Husky » Mon Aug 02, 2021 11:28 pm
Try to flatten the drawing to 2D.
Menu / Misc / Modify / Flatten Drawing to 2D
debbio
Post by debbio » Tue Aug 03, 2021 8:51 am
Thank you. In this way I can recreate the measure.. how did you know it wasn't a 2d drawing?
Post by CVH » Tue Aug 03, 2021 10:39 am
How did you know it wasn't a 2d drawing?
- By viewing it in a 3D application.
- By the Z coordinates not all being zero.
Values for Z is by preferences: :wink:
Menu Edit .. Application Preferences .. Widgets .. Property Editor .. Display Z coordinates
debbio
[Solved]Re: Error viewing file
Post by debbio » Tue Aug 03, 2021 8:03 pm
Ok! Thank you
