[solved] Mirroring Problem in Linux Mint
I have just converted an Asus U33J to Linux Mint Cinnamon 64 and loaded QCAD Pro (latest version). At the same time I have loaded QCAD Pro onto my Windows 10 pc. When I want to mirror something in the Windows 10 version everything works fine, but in the Linux Mint version the dialogue box fails to pop up so I am unable to complete the manoeuvre. Is this a minor glitch that can be fixed fairly quickly?!
Re: Mirroring Problem in Linux Mint
Both QCAD installation have the same settings for the Mirror Dialog?
Re: Mirroring Problem in Linux Mint SOLVED
Thanks. It turns out that I was (unnecessarily) holding the alt key down to lock the axis of reflection vertical, which blocked the dialogue box from appearing! All is now well so thanks again.
