[solved] Cursor not visible
ACM_Doug
Post by ACM_Doug » Mon Jan 25, 2021 8:19 pm
For many functions (eg. offset line) I have no cursor on the screen. If I move slowly I can see geometry highlighting and it appears there is a set of black crosshairs there. How can I correct this? The condition makes QCAD unusable for me.
Re: Cursor not visible
Post by andrew » Mon Jan 25, 2021 8:24 pm
The cursor should look like this:
Screenshot 2021-01-25 at 20.22.32.png (4.89 KiB) Viewed 3153 times
I.e. a black crosshair with a white outline.
What system are you on (Windows, macOS, Linux)? What background color do you use? Thanks.
ACM_Doug
Post by ACM_Doug » Mon Jan 25, 2021 9:59 pm
Win10 64. I uninstalled and reinstalled and it seems to be fixed. Perhaps I did something in the settings to mess it up. Seems okay now.
