OB (Best practice)
and D2 are failing all trials in the file.
It boils down to:
A) With an open polyline:
- An ending node ... Best practice is Delete Node (OD)
- Cut up (DI) at vertex and delete is the most certain option
- Break out Manual (B2) knowing the orientaion.
B) With a closed polyline:
Bug report at:
https://www.ribbonsoft.com/bugtracker/i ... sk_id=2176
How To remove a Polyline Segment 3.25.2.7
- RemovePolySegment.dxf
- (209.97 KiB) Downloaded 365 times
Re: How To remove a Polyline Segment 3.25.2.7
Update
OB = Intended behavior = Not intended to cut out segments.
B2 = Intended behavior (The poly doesn't intersect with anything)
