[solved] text tool issue
cccplex
Post by cccplex » Tue Jan 05, 2021 1:50 pm
Hi, I have an issue with the text tool where switching font height sometimes makes qcad unresponsive for a few minutes.
I described the issue in a the bugtracker.
Such bugs are probably difficult to resolve and/or system dependent.
Can someone reproduce this? See the steps in my last comment listed in the bug.
15.6 GiB memory - i7-9750H CPU @ 2.60GHz - GeForce GTX 1650 - Latest Ubuntu
Re: text tool issue
Post by CVH » Tue Jan 05, 2021 4:23 pm
Followed your steps by the letter.
2 >> 200: no problem
200 >> 2: none what so ever.
Win7Pro 32bit, QCAD Pro 3.25.2.7
About the screenshot: :roll: :wink:
cccplex
Re: text tool issue
Post by cccplex » Wed Jan 06, 2021 11:23 am
Thanks for checking. To be sure, by local font-height I mean the input box at top middle of the text tool window. Because in your screenshot is reversed from mine. :wink:
Re: text tool issue
Post by CVH » Wed Jan 06, 2021 11:42 am
Tried both ...
Shot is from the second trial to show the text is in the preview (and still selected blue/white).
Never understood why the the text preview has a fixed scale.
Similar as the preview of a hatch has a fixed scale but doesn't scale what is previewed.
With text it does
So,
3 methods work fine:
- both in the texteditor
- presetting the props and altering in the texteditor.
that make up a large set of combinations and none had any lag. :)
Very recent there was a topic about less threads may be more ... :wink:
cccplex
Re: text tool issue
Post by cccplex » Wed Jan 06, 2021 12:30 pm
Well, I spent a lot of time testing this and now my only option left is to reinstall the OS. Too bad I can not pinpoint the issue.
edit: After reinstall the problem was gone.
