Nothing Happening Now After Upgrade
sc285
Post by sc285 » Sun Dec 27, 2020 2:46 am
QCad Pro v 3.25.2.0
MacOS Big Sur 11.1.0
Nothing seems to be working now after upgrade to Big Sur 11.1.0.
If you click on draw line, you can do a starting and ending point but nothing shows on screen.
If I open an OLD drawing, and try to dimension say a rectangle side, the dimension shows up until you release the mouse button and it disappears.
If you try and draw a rectangle by entering coordinates, says input is invalid.
At this point I am dead in the water as nothing is working as it did previously.
Anyone else having this problem??
Re: Nothing Happening Now After Upgrade
Post by andrew » Sun Dec 27, 2020 11:17 am
This sounds more like you might be drawing on a locked, invisible or frozen layer. Please attach your drawing file and screenshots and indicate the exact error messages.
sc285
Post by sc285 » Sun Dec 27, 2020 5:12 pm
Full screen shot of new drawing (blank)...Clicked on icon to draw rectangle....cursor on screen but does not show up on screen shot (??)
Screen Shot 2020-12-27 at 10.04.19 AM.png (163.87 KiB) Viewed 5002 times
sc285
Post by sc285 » Sun Dec 27, 2020 5:14 pm
Second screen shot showing after clicking on screen (no anchor point shows up) and now Qcad asking for second point.
If use mouse to select second point, nothing happens (again, cursor does not show up on screen shot)
Screen Shot 2020-12-27 at 10.04.31 AM.png (59.14 KiB) Viewed 5002 times
sc285
Post by sc285 » Sun Dec 27, 2020 5:15 pm
And this is what happens when I try, rather than clicking on the screen for second point on rectangle, entering coordinates instead
Panchdara
Post by Panchdara » Sun Dec 27, 2020 6:11 pm
Windows 10
sc285
Post by sc285 » Sun Dec 27, 2020 6:33 pm
That seemed to work.
Apparently the .ini got corrupted or something. Had to reset a few things but everything back to normal.
Thank you! Have a good week!
Rob
