Hi everyone,
I recently bought a QCAD Pro license in order to be able to use the scripts. The images generated by dwg2bmp (from dxf files) look fine, but I also need to draw the origin. Using the parameter "-origin" seems to have no effect. Can anyone reproduce/confirm this problem or ist there some workaround?
Thanks & merry Christmas,
Martin
dwg2bmp script: origin not drawn
Re: dwg2bmp script: origin not drawn
Thanks. Bug report added at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2158
... and already fixed
Wow Andrew, that was really fast. Thank you so much
