The property editor shows a value of "0.01" as "0.01000000".
[solved] Property Editor shows trailing zeroes
From a QCAD user:
Re: [solved] Property Editor shows trailing zeroes
The format for dimension labels is also used to display values in the property editor. Please check your settings for:
Edit > Drawing Preferences > Dimension > Dimension Settings > Label > Show trailing zeroes
