Qcad Pro: trim/extend/chamfer not working
Giuliano69
Post by Giuliano69 » Mon Nov 23, 2020 4:48 pm
Found a situation where two simple lines, cannot extended to merge, no matter which tools you try to use
I did a cut and paste of the two lines, and created a new file... same situation... in the attachment
IF you try to fillet (eg r=50), you will see that the circle is drawn in the "opposite" way.... and the center of the circle is in the wrong place...
If you try to chamfer, it seems that the tool is getting the wrong side of the second line...
Maybe something in the definition of the edges to be worked on is not working properly.
Am I missing something or there is a bug present ?
BR
Giuliano
Ubuntu 20.04
Versione: 3.25.2.0 (3.25.2)
Internet: QCAD.org
Data Compilazione: Sep 4 2020
Revisione: 4a61501
Versione Qt: 5.14.2
Architettura: x86_64
Compilatore: gcc 5.4.0
bug_01.dxf
(99.89 KiB) Downloaded 326 times
Re: Qcad Pro: trim/extend/chamfer not working
Post by CVH » Mon Nov 23, 2020 4:53 pm
These entities have a non-Zero Z value.
Try Menu .. Misc .. Modify .. Flatten
Giuliano69
Post by Giuliano69 » Mon Nov 23, 2020 5:26 pm
Thanks... it works !
BTW .. in the property windows I can only find x and y coordinates...
HOW did you realize that they had a Z coordinate, and it was not zero ?
BR
Giuliano
PS
Being Qcad a 2D program, shouldn't Qcad notify that the objects been tooled are NOT in place ?
Post by CVH » Mon Nov 23, 2020 5:41 pm
Menu .. App Prefs .. Widgets .. Property Editor .. Display Z
Your PS:
No, QCAD = 2D, the user should know what he is doing.
- Ask Andrew in a new topic
- File feature request
