I am running the latest QCAD Pro, 3.25.2.0 64-bit on Windows 7.
Could be a bug as it seems to show the same behaviour as viewtopic.php?f=32&t=4776 but I thought I'd check here in case I'm missing something obvious. I'm trying to remove part of a polyline as indicated in the attached. I can enter the first break point but not the second.
Break out Manual issue
- Break out Manual.dxf
- (102.2 KiB) Downloaded 432 times
Re: Break out Manual issue
Thanks. Moved to bug tracker at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2133
Version 3.25.2.7:
Second reference is operational.
Although, the larger part is removed.
