begin line relative to point
- Newbie Member
I'm trying to begin a line relative to a chosen point (@x,y). I've used it in other CAD programs but can't seem to find a similar command in QCAD. thanks
Re: begin line relative to point
You can set / change the position of the relative zero point anytime in QCAD:
https://qcad.org/doc/qcad/latest/refere ... lativeZero
The enter a relative coordinate for the first point of the line.
- Newbie Member
yes, that would work but, too many hoops.
I want to able to say begin this line at a position relative to another known point. It's typically a snap, really useful for me.
Why not draw the new line beginning at initial reference point, then MV to a point that is relative to that point? (perhaps a little less cumbersome to moving relative zero)
Windows 10
- Newbie Member
The most simple appears to be to draw a construction line relative to the base point and then begin the line. Then erase the construction line.
Hi Bottom,
2. Start the 'Line' command. (Two letter shortcut LI. (That's an i, not one)).
3. When prompted for 'First point', enter a relative coordinate in the command line (e.g.' @x,y).
Regards
riverbuoy
1. Set relative zero point using two letter shortcut RZ. (see Andrew's post above).bottom-dragger wrote: ↑Wed Sep 30, 2020 8:02 pmI'm trying to begin a line relative to a chosen point (@x,y). I've used it in other CAD programs but can't seem to find a similar command in QCAD. thanks
Regards
riverbuoy
