Hi Andrew
I'm having some trouble here , this has only happened with the recent release..
I get error messages opening the file can't open file, on restart it went away?
I was testing a very basic pattern... I've also had a few issues with the program
hanging " no response " . never had these issues in the past...attaching the drawing
to see if you can see anything wrong with it... as I said it opens now?
Cheers
John Hyslop
PS Just added Pattern in case it has an issue with it... testing an Imperial pattern
[ Opened After Reboot ]This DXF won't open in QCADCAM 3.25.1.0
- Premier Member
- PLATE-05B.PAT
- (717 Bytes) Downloaded 311 times
- Pattern Testing.dxf
- (194.72 KiB) Downloaded 324 times
Re: This DXF won't open in QCADCAM 3.25.1.0
John,
File Opens in QCAD Version 3.24.3.10 (3.24.3.10)
Straight away by double clicking the link in the forum.
Reports: Format: R18 (2004) DXF Drawing (OpenDesign)
For sure it's not the hatch ...
I think I can tell that with my hatching backgrounds.
For sure it aren't the two polys.
As you say it opens now ... We'll never know what happened before the reboot.
Here it's back in R32:
BTW: This is going to be a very steady hatch
- Premier Member
Re: [ Opened After Reboot ]This DXF won't open in QCADCAM 3.25.1.0
Hi Andrew
I think there is a problem, this has never happened before this file took 3 reboots before it opened?
created in Qcad and never opened in any other application, I'm going to install V3.25.0 even though it has
the dimension bug, I rarely use that dimension tool...
Any Ideas what's going on ?
File attached it opens now... but attaching anyway
Best Regards
John Hyslop
Best Regards
John Hyslop
- PLATE-01A.DXF
- (218.77 KiB) Downloaded 325 times
Sorry, no problem with that file on my machine ....
None here too.
Got the same file by another channel.
