I am a new user of QCAD Professional.
I have opened a file drawn using different software - I would like to print a "window" is this possible.
I have made modifications to this drawing and tried saving it in both "dxf" and "dwg" formats and then opening the saved file with "DWG TrueView" but it does not show the dimensioned text or arrows when opened in "DWG TrueView". The extension lines are there but not the text or the arrows.
Roger Harrison
Printing a window & opening saved drawing with DWG TrueView
- Registered Member
Re: Printing a window & opening saved drawing with DWG TrueView
Please attach your drawing file, so we can reproduce the problem here.Roger Harrison wrote: ↑Sat Aug 29, 2020 9:51 amI have made modifications to this drawing and tried saving it in both "dxf" and "dwg" formats and then opening the saved file with "DWG TrueView" but it does not show the dimensioned text or arrows when opened in "DWG TrueView". The extension lines are there but not the text or the arrows.
Note: I've split this topic as there are two questions / issues in one post. You can find my answer to the first question at:
https://www.qcad.org/rsforum/viewtopic.php?f=32&t=7540
Please post one question / problem per topic, thanks.
